Go to Post My favorite quote from my 4 year old daughter is, "if it works, who cares?" - drwisley [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 06-12-2005, 16:52
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: New calculation of Reputation
Originally Posted by Billfred
Of course the reputation system could be modified, improved, or fiddled with from here to Tuesday.
However, as the saying goes, there comes a time to shoot the engineer and build the thing. The engineer has been shot, the thing has been built, and it still functions half-decently.
If you really are worried about whether someone's rep is wrong, there's a simple solution: give rep appropriately. Over time, folks will settle to about where they should be.
Exactly. I have a good example. Kevin Watson. The man has done as much for FIRSTer's as almost anyone I know, but because he only posts when he can help, he isn't as visible. Now, don't be a sheep because I told you to, but all you programmers and anyone else out there, think about about how Kevin has helped you, and act accordingly. Thats how rep. should work: if you think someone honestly deserves a rep. point, then good! Take care of it!
Another example. I recently recieved some rep. that I simply did not deserve. I didn't do anything for it. However, it didn't move my rep. visible, which is good. if I find it moves my rep. inappropriately, I will contact Brandon to see if he can remove it. And thats where it starts: if you're not honest with yourself, the system falls at it's knees.
Actually Brandon, is there a way i can remove rep. short of drawing a red point?
-Sir Francis Bacon
-Albert Einstein
Appropriate use of reputation points mtrawls CD Forum Support 62 11-02-2008 14:37
Reputation Deflation Joe Matt CD Forum Support 26 22-07-2005 00:36
suggestion to reduce existing reputation for upcoming season Joe Ross CD Forum Support 44 03-01-2005 01:24
Reputation and private messages RyanMcE Chit-Chat 8 22-04-2004 07:40
Reputation systems scares you away from post Ryan Albright Chit-Chat 26 21-02-2004 16:45
