Go to Post Tinkerer math = engineer - MikeE [more]
Unread 07-12-2005, 00:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Where to get miniature hydraulics? OR...
Originally Posted by 114ManualLabor
The use of a shock piston would not work, because of the holes present inside the cylinder. While in pneumatics or hydraulics there is a seal between the two chanbers, there are small holes in a shock absorber.
Originally Posted by sanddrag's post above
Could I use a standard RC car oil filled shock, fill the holes in the shock piston (or make a piston without holes)...
Unread 07-12-2005, 01:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
What about using a food-grade medium, like glycerine? That would very likely be safe for the seals in a standard aluminum & stainless piston. Or to be absolutely sure, use it with a food-grade piston, with nylon or delrin end caps and stainless body; those seals have to be especially nonreactive.
Unread 07-12-2005, 13:31
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
you could always find out what the seal in pneumatics is made of then see if the material is "edible" by the fluid
KK4KQO
http://voltair.us
Miniature Innovation First RC System BSMFIRST Technical Discussion 13 27-07-2001 02:24
Miniature Robots David Kelly Technical Discussion 4 31-05-2001 22:06
