Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 07-12-2005, 15:30
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Variable Diameter Wheels
yeah im bad at explaining, if the person on my computer leaves soon i can finish inventoring it, otherwise it may have to be hand drawn and scanned oh well
heres try II:
each wheel is mounted on a bearing setup that rotates on the base, the wheel has a shaft that runs into it, the shaft goes up to the pivot point and has a u-joint at that spot, the u-joint connects to a telescoping rod inside the robot which is then connected to the motor however you like.
KK4KQO
http://voltair.us
