Go to Post I am definitely not a battery or battery charging expert (far from it) but I do know enough to be dangerous (I stayed in a Holiday Inn Express last night)... - Don Wright [more]
Unread 07-12-2005, 17:41
vashthestampede vashthestampede is offline
None #0340
vashthestampede is an unknown quantity at this point
MAX 8 installation issue
alrite so our team received our copy of MAX 8 and we tried to install it butwe install it under network license. we send in for and receive the license for MAX 8 i choose it using whatever it asks me to do and it won accept it. it seems odd to me and installation for network license really didnt come with a hand book so can someone help me out. walk me through it or whatever
Unread 07-12-2005, 19:11
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: MAX 8 installation issue
I don't believe that you get a network license with FIRST. I believe you have to use the stand alone license because you only get to use it on 1 machine. Try that and maybe it will work (I however haven't installed 3ds max 8, partly because there is no FIRST in college). Hope that works.
Eric
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 07-12-2005, 21:03
None #0340
Eric
i had already tryed that it even says on the disk that its a network license unfortunately for 5 people which doesnt make sense it would be easier if they did it for 5 stand alones
Unread 07-12-2005, 22:00
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
5 Standalones would mean they would have to send you 5 cd-keys. I did not see it mentioned anywhere that this was a network license I installed it as standalone, then when trying to authorize it, it told me the key was for a network license and that I need to uninstall and reinstall as network. VERY INCONVENIENT!!! Also can someone explain to me how network licensing works? Do all of the computers need to be on the same network to work. Getting 5 (even just 2, for that matter) fairly decent computers in the same room is very difficult for our team. Is it possible to set up a license server accessable via the internet? Does anyone have any ideas/insight? Post your MAX8 stories here.
Unread 07-12-2005, 22:45
None #0340
see thats what im talking about everyone is confused and doesnt know how to install it some kind of instructions would of been nice or at least a simple easy to install stand alone license.
Unread 08-12-2005, 01:17
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
This surprises me that they handled it this way, though I guess it seems to be the logical choice. I've never installed Max through a network, though I'm pretty sure they'd all have to be connected somehow. I guess FIRST and Autodesk are aiming towards the computer lab type setting. My suggestion would be to contact Autodesk if you're having problems with installation. I've found that phone calls would probably work better than e-mails, since my track record with Autodesk getting back to me isn't very good.
Good luck.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 08-12-2005, 14:09
None #0340
Good luck.
I've covered that base to it got me nowhere they just sent an FAQ to me that didnt even help is there neone out there that has got it to work especially in the rochester area
Unread 08-12-2005, 17:00
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
No worries.. It's really not that difficult to install the Network License.
Every FRC team has a copy of 3ds max 8 that allows for 5 seats. Each team gets one license, which is a Network License. Autodesk will not convert it to a stand alone license if you call them. I've tried.
Preparations:
1) You want to install the network license on a server; the server can be any computer which other computers have access to. If you are just installing on ONE computer, the network license still works, too.
2) Ideally, you want to setup a folder on your network that can be accessed by all computers. For example, the way I set up the network license was I put the license file on an FTP server and the other computers access the FTP server for the license file.
3)Find out your server's name, START>(right-click) on MY COMPUTER > Properties > Computer Name Tab. You will need this when you install 3ds max 8 and license activation.
4) It is important that you install 3DS Max 8 with the Network License option, not Stand-Alone. Do this for all the computers you will be working with. But before you do this, install the network license first.
5) Now, on the server, install both network license manager and network license activation. Instructions can be found on the 3dsmax8 dvd.
6) If your comptuer does not have a DVD drive, you can use another computer that has a DVD drive and share that drive so that the server can access the DVD.
7) Once installed, run 3DSMAX8NLA.exe which can be found in \Program Files\Autodesk Network License Manager\Network License Activation Utility\enu\ You will need an internet connection. Fill out the information. Once you;ve finished, it should generate a license file; it'll ask you to save it on your hard drive.
8) Once you have the license file, put it in a folder on your server.
9)now, open LMTOOLS by going to START>ALL PROGRAMS > AUTODESK > NETWORK LICENSE MANAGER > LMTOOLS.
10) go to this thread http://www.chiefdelphi.com/forums/sh...ad.php?t=40655 and read post #2. This wil show you how to setup LMTOOLS.
10)install 3ds max 8 with the Network License option and input the server name in the Network License Server field. Use the serial number that comes with your copy of the software.
11) The first time you open 3dsmax 8, you will be prompted to find the license file. This shouldn't be hard if you setup your network correctly.
I could take screenshots if you guys need it.
Hope I've helped
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 08-12-2005, 18:13
kcy88's Avatar
Animator
AKA: Kevin
here's some screenshots for setting up LMTOOLS. do this after you installed the Network License Manager and after you have activated the license.
click here
In figure 1, you want to go to the Config Services tab. Type a new name for the service; in my example, i put "Autodesk". Find the files like shown in the screenshots. For "Path to the Debug log file", just choose any folder. You won't find any log file for your initial installation. Check USE SERVICES and Start Server at Power Up.
In Figure 2, go to the Service/License File and choose CONFIGURATION USING SERVICES.
In Figure 3, go to the Start/Stop/Reread tab. click START server and EXIT LMTOOLS. then reopen LMTOOLS.
FIgure 4: To check if your network license is running, go to SERVER STATUS and click on PERFORM STATUS ENQUIRY. If you scroll down, you can see a total of 5 licenses issued.
Unread 08-12-2005, 22:18
AKA: Jake
Definately repost and get it stickied.
Thanks a ton!
Jake
Preparations:
Hope I've helped
Unread 09-12-2005, 10:53
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Does anyone know if it has a "free trial"?
In other words, can it be installed on any computer for 30 days, like Version 7?
Unread 09-12-2005, 14:04
I saw it has a 30-day free trial if you install it as an individual license. That might also be the case with the network license server, but I didn't check before the license was installed.
Unread 09-12-2005, 15:50
AKA: Jake
Yes in standalone the software goes into a 30-day trial when you do not activate it.
Unread 12-12-2005, 10:13
Noggy3230 Noggy3230 is offline
None #1038
Noggy3230 is an unknown quantity at this point
Our team is also having installation problems. We installed Max 8 on three computers and made one of them the "server". We thought we got everything to work but Max won't open on the "server" computer....
It opens on the other two computers on the network. When we try to open it on the "server" the splash screen comes up and it looks like it's loading then it just closes...
any ideas?
Unread 12-12-2005, 10:53
Mr. Steve's Avatar
Mr. Steve Mr. Steve is offline
No relation to Mrs. Steve
#1626 (Falcon Robotics)
Mr. Steve is an unknown quantity at this point
Autodesk referred us to this file regarding Inventor, but I would assume its probably the same for 3ds.
http://download.autodesk.com/prodsup...6_Autodesk.doc
Sounds interesting, especially the ability to "borrow" licenses from the server.
Falcon Robotics
Heroes of Engineering Comic: Dean is the December Issue Vince Dean Kamen's Inventions 5 01-12-2005 12:00
questions about the 3ds max license BuddyB309 3D Animation and Competition 3 27-10-2005 16:32
Lightwave to Max Converter? Ian Curtis 3D Animation and Competition 0 16-05-2005 12:33
3ds max 7 installation problems sirbleedsalot 3D Animation and Competition 1 15-05-2005 21:18
3D Studio Max 6 Question!! Srkasner Inventor 7 21-01-2004 17:05
