#17
Re: Alternative to limit switches?
Sparks,
That is true for most of the prepackaged sensors but the actual Hall effect device is much like an optical transistor. The magnetic field will cause an increase in current in the transistor or send it into saturation. Individual Hall transistors are available if you look for them. Interfacing is then up to you. |
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| limit switches | stephenthe1 | Programming | 28 | 11-05-2005 16:37 |
| Common Ground on Limit Switches | Gary Bonner | Electrical | 4 | 18-02-2005 13:24 |
| Limit Switches help. | Xufer | Programming | 9 | 21-04-2004 21:21 |
| Team selector switches on ISAAC | Lloyd Burns | Robotics Education and Curriculum | 0 | 17-12-2002 08:32 |
