Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Unread 11-12-2005, 19:17
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Tapping Into Kit Transmission Casing
I don't have the physical pieces in front of me, so perhaps someone with firsthand knowledge can help me out here.
The transmission provided in last year's kit were encased in a housing made of two pieces, held together by 1/4-20 UNC bolts at the four corners. The assembly instructions spec. 1/2" length on those bolts and, similarly, the drawings show that they're tapped to 12.7 mm.
I want to tap the other end of those four holes and bolt the transmission to a plate using four separate 1/4-20 screws so that, if I remove the transmission from the plate, it'll stay assembled.
This seems perfectly plausible, but I am working on an abbreviated timetable and can't wait until I see the transmissions again to be sure. Can someone verify that I'm not crazy and this is possible?
Thanks.
--Madison--
...down at the Ozdust!
Unread 11-12-2005, 19:24
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Tapping Into Kit Transmission Casing
Thanks.
Yes, this is possible.
Not only is it possible, but that was one of Paul's original design intents.
(He's got this "thing" for face-mounting transmissions.)
I've got one in front of me, and I double checked, just to be sure.
-JV
Unread 11-12-2005, 19:26
Madison's Avatar
FRC #0488 (Xbot)
-JV
Awesome. Thanks, John.
Y'all can expect an order for two of those transmissions soon, I believe.
--Madison--
Unread 11-12-2005, 19:28
JVN JVN is offline
@JohnVNeun
While you're at it, can I interest you in some server-racking? Or possibly something else we make some money off of?
Unread 12-12-2005, 00:29
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Or maybe some Vex Addons for your amazingly cool brother?
Matt Krass
Unread 12-12-2005, 19:24
President, VEX Robotics, Inc.
Matt,
John is correct. If you look at the manual (down-loadable from IFI website), chapter 5 shows the engineering drawing for the housing. The through hole for the tap drill is specified at 5.0mm. This is actually undersized for a 1/4-20 (but will work just fine). It is the perfect size for an M6-1.0 metric screw. In addition to "a thing" for face mounting, I have "a thing" for the metric system.
Your intended use of the mounting face is well within the design specifications for the transmission housing.
-Paul
Unread 13-12-2005, 14:29
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
So THAT is what you do with all your spare time!
-dave
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Kit Transmission Arm Config Update Paul Copioli Kit & Additional Hardware 0 21-01-2005 15:07
Kit of Parts - Sprocket Spacers? and Transmission Lubrication? wmurphy Kit & Additional Hardware 10 13-01-2005 01:09
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
