Vex Easyc vs Mplab
Right now I'm the programmer for my FRC team and we just got a vex kit, so we can make a team for next year. I'm currently trying to decide if we need to get the easyc program or not. I know that mplab and the frc programming software works just fine, but I was wondering if it is worth getting easyc just to make it easier?
Re: Vex Easyc vs Mplab
You'll need to buy the programming kit to get the vex programming module. A USB to serial converter is included along with a cable. The kit includes Easy C 1.0 which will get you going. Easy C is now at version 2.0. While you can do allot with the version in the box , version 2.0 includes improved program flow commands, user functions, global variables, and some other improvements. You might want to pick up some encoders and a sonar module too. This will get you started. The younger members on the team will find programing easier with Easy C. After they increase their skills, they could try the mplab programming. With mplab there is no support for the sensors, you'll have to program your own functions and commands.
You can really use either way to program the Vex Controller. I personally like to use EasyC, but whichever one you choose is up to you. |
So... just plug right on in and upload?
Also, is there any default code that's been modified from the FRC's MPLAB code that we could use? (The thread would work very nicely...) |
All the MPLAB default code for the Vex Controller is located on the VexLabs downloads page. |
EASYC 1.0 does not give quite as much programming freedom as MPLAB but it doesnt require as much knowledge and skill, if there is someone not accustomed to programming then EASYC is probably the way to go but if they are used to writing large programs from scrtch the dialogs in EASYC will get very anoiying very fast, i have used it to program the VEX bots but wont touch it for FRC,
but then again i carry around a binder with all the latest code modifications i have made to the default code in attempt to create my own default code Happy choosing, Cuog |
#7
I think you should try EasyC 2.0. Its vastly improved Over EasyC 1.x.
#8
Okay, I downloaded the Vex Master Code just today (d**n MMOs
) but... .bin files? How to open?I'm just their PBASIC programmer, go easy. I don't know that much about filetypes between .bsx and your classic .h and .c files. |
#9
Re: Vex Easyc vs Mplab (UPDATE)
From wandering around CD, I found that there's a different ifiloader for the VEXBots, but I have no idea where, if it exists. Any info?
#10
Yes there is a different IFI Loader program for the VEX bots, I dont remember where i downloaded it from but it was either IFIrobotics.com or VexLabs.com perhaps one of the others but look around USFIRST.org for a while and there will be a link to get you there eventually
#11
Happy to help
#13
For the record, I believe the new version of IFI Loader (v1.0.12) supports Vex.
#14
hello, easyC doesn't even have the capability to pass parameters in addition you can't write advanced C code because it gives you what they call modules and thats what you use as code. I highly recommend not using easyC to program your Vex Robot or whatever type of robot you own. easyC is THE worst software I've ever seen for programming.
#15
I think using EasyC is a great resource especially for prototyping fast. After your team has played with it for a while and feels that they have grown past it they can use the exact same code (at least for FRC) to write their code in MP-Lab or Eclipse. If you have never programmed before I definitely recommend EasyC. |
| Programming Vex w/ MPLab | dababyjebus | FIRST Tech Challenge | 27 | 25-04-2008 09:11 |
| Milwaukee VEX League | Kevin Kolodziej | Off-Season Events | 7 | 05-11-2005 17:58 |
| White Paper Discuss: VEX / intelitek easyC programming document | dez250 | Extra Discussion | 3 | 15-09-2005 15:20 |
| An IRI VEX Thank You | John Wanninger | Thanks and/or Congrats | 0 | 26-07-2005 00:12 |
| VEX Robotics | vexrobotics | FIRST Tech Challenge | 8 | 30-03-2005 23:25 |
