Go to Post I'm not overdosed, I'm not even addicted. I just choose to never, ever, ever leave FIRST. - SL8 [more]
Unread 12-12-2005, 01:12
114gopher's Avatar
114gopher 114gopher is offline
Co-Captain
AKA: Adam Garcia
FRC #0114 (Eagle Strike)
Team Role: Student
114gopher will become famous soon enough114gopher will become famous soon enough
Send a message via AIM to 114gopher
Tank Tread Stair Climber
Hi
I was wondering if anyone had any ideas on how to go about building a tank tread robot that can climb stairs. How do I determine how high the treads should be, etc? Ideally, it would end up being able to carry a laptop and enough battery power that it can roam the halls of an office building for a while. Any ideas?
Thanks
Unread 12-12-2005, 01:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Tank Tread Stair Climber
I think JPL's Urbie robot has done it the best of any I have seen. (do a google image search for jpl urbie)
The Mythbuster guys made a Vex one http://www.botmag.com/articles/mythb...stem_1. shtml but I wouldn't expect it to be climbing staircases.
Unread 12-12-2005, 02:52
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Just FYI, Urbie in based on iRobot's PackBot mobility platform.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-12-2005, 08:13
REVving up for a new season
FRC #2848 (All-sparks)
the general rule for climbing stairs if you don't if you don't want to have a special device for lifting above the lip is to make the diameter of the wheel/tank sprocket large enough so the axle is above the lip of the stairs. Normal steps are approx 8 inches so most anything larger then that will be able to climb.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 12-12-2005, 09:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
In my opinion, the most frequent mistake made by folks who are trying to design a robot to climb stairs is that they do not thinking about CG management.
It is relatively easy to get a chassis to climb a staircase. It is often much more difficult to have a robot with an arm or other tall mechanism not fall over while the chassis climbs the stairs.
Think about how your center of gravity moves as your robot climbs the stairs. If your CG ever gets behind the rearmost point of contact with the floor, you robot WILL tip. Even if it gets close, dynamic effects and other robots often make it likely that the robot will tip.
I highly recommend "wheelie bars" or other mechanisms to catch you if you tip. Even betten, I recommend trying to design a your stair climber so that you can climb stairs while keeping your CG between the wheels.
Joe J.
Team #88, TJ2
Unread 12-12-2005, 09:11
Generator of Entropy
FRC #2973 (The Mad Rockers)
Or, you can add an angle to the front of the robot with smaller sprockets on top and bottom, such as this one for the game where we had to drive up onto the puck.
As important as the treads is where the CG of the robot is; in G'doinkle (shown in the link) we had a minimum speed that we hit the puck in order to have the angular momentum sufficient to overcome the force that was trying to flip the robot backward as we drove up onto the puck. Gary Jones (one of our engineers) actually calculated that speed and we proved his calculations by experiment. Remember that "stairs" is different than "stair" - you not only have to get up on or over one, you have to keep driving at that angle.
Unread 12-12-2005, 09:48
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
if you're looking at treads...this website may be able to supply you with something
http://thistle.uk.com/stairclimbing.html
they're pretty beefy, and come kevlar reinforced.
plus there's real bits of panther in it, so you know it's good.
Collin Fultz
Unread 12-12-2005, 17:13
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
The MythBuster's Vex stair climber looks pretty cool. Maybe you can get ideas from that. The most important thing though, as it has been said before, is CG management. If the robot tips, it is most likely going to fall down the stairs. Another possibility would be something like the stair climbing wheel chair designed by Dean Kamen (can't find a link).
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 12-12-2005, 17:31
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The wheel chair that Dean invented is the Independence iBOT 4000. You can see a cool video of the iBOT climbing staircases here.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-12-2005, 21:41
114gopher's Avatar
Co-Captain
AKA: Adam Garcia
Team Role: Student
I should clarify...
It would hopefully be able to climb a long flight of stairs, not just one. Thanks so much for everyone's advice, it'll really help a lot!
4WD, Tank treads and gear ratios. Pipisongo Technical Discussion 4 07-09-2005 15:38
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
