Re: Check out our cannon bot!
I can confirm that sprinlker valves will work off of 24VDC. For PVC, don't put any more than maybe 25 psi in it without gluing all the pieces, and when you glue them, let it dry for a long time to make sure it is fully cured.
But air cannons are very fun projects. You can easily make a quite nice fog horn too. One thing I did while messing around with this stuff was to drill out a PVC end cap and thread in a quick release fitting for the air hose. It worked fine, and was very easy to do. Just to let you know in case you were wondering how to hook up the air, that is one way. |
As promised, here is the video from Sunday night at the Sacramento Kings game.
Please forgive the quality, I have not yet had a chance to clean it up. I will once I get the correct software running. Team 1147 at Arco In the background you will hear the team being announced just after the shirts land in the upper deck! |
Good place to start is wikipedia - search for potato cannon. In there, there is a link to here: http://www1.iwvisp.com/thehalls/ggdt/ where you can get software to calculate theoretical velocities and stuff. He also has a page showing how to modify a sprinkler valve for rapid discharge (for manual firing), and pages discussing different designs of spud guns and paintball guns.
Make sure you read various safety warnings about PVC guns! Use only pressure-rated pipe, prep the pipe and use primer, allow the cement to cure for at least 24 hours and don't use them in hot or cold weather. You could probably modify a sprinkler for pneumatic opening, then use a 12 volt air valve from one of the old pneumatics kits as the trigger instead of the solenoid. Our latest toy is a 20 lb. propane tank connected to a 1 inch pipe. Overkill, yes, but shooting a carrot at something solid makes instant carrot juice. More like orange fog. |
My 16 year old does the building, I just buy the goodies.
My favorite is a 2 liter soda bottle with a 1/4 to 5/16 inch (or so) hole in the cap. About a 6 to 7 second spritz of propane from a torch, put the cap back on, put it on some sort of guide rail and light it. WHOOSH. It ignites and the exhaust goes sonic, so watch your ears and don't get burned by the hot exhaust. It'll send a bottle quite aways. You have to squeeze the bottle a few times to purge between firings. The bottles start to deform after several launches. |
#7
I always hear people talking about using sprinkler system valves for homemade pneumatic projectile launchers. The valves on my sprinkler system are motor actuated ball valves. They take about 4 seconds to open fully. This seems rather slow. Is this what people are talking about or is there some other tyoe of sprinkler valve? I have built several devices using quick release valves from semi-truck air brake systems and they have worked well.
#8
Some pics and video of one of the meanest Vex bots known to exist:
http://web.mit.edu/scolton/www/tankbot1.jpg http://web.mit.edu/scolton/www/tankbot2.jpg http://web.mit.edu/scolton/www/tankbot3.jpg http://web.mit.edu/scolton/www/tankbot4.jpg http://web.mit.edu/scolton/www/tankbot_clips_web.wmv http://web.mit.edu/scolton/www/tank_slow_web.wmv Last edited by ZZII 527 : 13-12-2005 at 20:10. |
#9
Check here: http://www1.iwvisp.com/thehalls/ggdt/
For a sprinkler system, I'd imagine a motor-actuated ball valve is better. You don't want to open or shut a sprinkler (hydraulic) system quickly. But a cheap valve may be better suited to pneumatic operation, especially as modified. I think these valves are about $16., last I remember. |
#11
Now to rig up a motor to a compresser to charge our two large tanks - hmmm, might need a deep cycle marine battery as well.I heard about Elk Grove's (1147) T-Shirt Launching robot at the Kings game - if you do it again let us know (not ride your coat-tails, but to promote robotics of course) we'd be happy to join you out there. |
#12
![]() BTW, did you follow the link and see the short video I posted a few frames back? You should have seen the smiles on these kids faces after they came off the court! <--- That's what they all looked like.In fact, here is a link to a picture I snapped as they were exiting the court. It doesn't even do justice to what we saw once they got off the court and thought about what they had just done. |
| sphere bot | Veselin Kolev | Technical Discussion | 36 | 03-03-2005 00:03 |
| kit bot wireing | sirbleedsalot | Electrical | 5 | 27-01-2005 17:59 |
| Help! My 2003 Bot compressor won't shut off | Jack21 | Control System | 10 | 11-02-2004 12:24 |
| Team 1072 (Harker Robotics Team)'s bot: Tork | AlbertW | Robot Showcase | 8 | 19-02-2003 13:19 |
| Check out ma bot! | Devil's Kid | 3D Animation and Competition | 1 | 09-02-2002 13:40 |
