Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 03-12-2005, 21:38
FRC #0701 (RoboVikes)
Robotic Rocket
Hi , just for fun me and some others honors physics students decided to enter a Rocket building contest.. the challenge is to build a rocket that carries an egg to 800 feet high and back in 45 seconds (the closer to these numbers you are the higher your score)
We are thinking about having 2 ejection charges, one that blows up the rocket at 800 feet (to stop its climb), and another that deploys a parachute at an optimal time. We're gonna use a pic controller hooked up to an altimeter.
what approach would you guys take?
Team 701
Unread 13-12-2005, 21:29
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Robotic Rocket
Interesting concept, but I have a few questions:
1. Does the egg have to stay intact?
2. What are you using for your charges?
3. What kind of altimeter are you using?
Unread 13-12-2005, 21:42
CraigHickman
Posts: n/a
Re: Robotic Rocket
Just a small note:
I've done a competition like this, and only relying on a parachute is not very safe. Have some back up insulation around the egg, as it will get hit pretty hard. Another small thing: try and test out your ejection charge before the test, because the judges will most likely want a whole egg back, not just some black ash.
And, on a closing note, I'm gonna quote an old teacher of mine. "When in doubt, copy NASA." Go for 3 parachutes, just for added stability. However, make sure you don't use too large parachutes, or you might have the egg drift too far when coming down.
Unread 13-12-2005, 21:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Robotic Rocket
I'm not sure what you're refering to about "blowing up" the rocket.
Are you talking about a normal ejection charge that just shoots out the top of the rocket body?
Because that will halt most of it's upward movement, if not push it downwards, and it will eject your payload.
I'm not entirely sure how you'd go about keeping the parachutes attached to the egg from deploying at this point though.
Ideally you'd probably want to be able to use an engine that would put the apex of the rocket's trajectory at just over 800 feet, and then you could time the ejection charge to go off once it's fallen as low as you can comfortably open the parachutes.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-12-2005, 22:08
Gdeaver Gdeaver is offline
FRC #1640
Re: Robotic Rocket
If it's the contest I'm thinking of, additional electronics are not allowed for the ejection charge. You may want to get a copy of a program called Roc Sim. It's a combination of a cad program and a simulation program. With it you should be able to design a rocket-engine combo that gets very close to the altitude by design. One parachute for model rockets is more reliable than more. If you can use additional electronics then a pic sampling a pressure sensor like a Freescale MPX4115 is the way to go. 10 bit sampling would be best. As for the time it takes the rocket to come down under chute, there are some web sites with descent rate calculators.
Robotic fish swim in a aquarium! mechanicalbrain Chit-Chat 4 09-10-2005 02:57
NASA Schedules Robotic Spacecraft Launch Mirza95vx General Forum 2 07-04-2005 00:33
Robotic Couch Drew Hopman General Forum 22 10-02-2005 13:54
Robotic Competitors Uniform dennis_team40 General Forum 5 06-02-2005 15:44
X-Prize Rocket Explodes Joshua May Chit-Chat 2 09-08-2004 17:12
