Go to Post It's nice to see how patient people will be on here even with people who are 99.9999% trolling. Something something GP. - Chris is me [more]
Unread 13-12-2005, 19:06
Umm Errr...
Re: Check out our cannon bot!
I always hear people talking about using sprinkler system valves for homemade pneumatic projectile launchers. The valves on my sprinkler system are motor actuated ball valves. They take about 4 seconds to open fully. This seems rather slow. Is this what people are talking about or is there some other tyoe of sprinkler valve? I have built several devices using quick release valves from semi-truck air brake systems and they have worked well.
1139 Alumni
Unread 13-12-2005, 19:41
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Some pics and video of one of the meanest Vex bots known to exist:
http://web.mit.edu/scolton/www/tankbot1.jpg
http://web.mit.edu/scolton/www/tankbot2.jpg
http://web.mit.edu/scolton/www/tankbot3.jpg
http://web.mit.edu/scolton/www/tankbot4.jpg
http://web.mit.edu/scolton/www/tankbot_clips_web.wmv
http://web.mit.edu/scolton/www/tank_slow_web.wmv
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 13-12-2005, 21:23
occra 23.
AKA: ryo
None #1481
there are solenoid ones. which would mean they are fast.... but apperently according to a link someone else posted before, those solenoids still arent fast enough. im planning to get a standard solenoid one soon. see what i can make outta it. i have some big plans for next spring.
Unread 14-12-2005, 02:02
Dick Linn's Avatar
no team (Synergy)
Check here: http://www1.iwvisp.com/thehalls/ggdt/
For a sprinkler system, I'd imagine a motor-actuated ball valve is better. You don't want to open or shut a sprinkler (hydraulic) system quickly. But a cheap valve may be better suited to pneumatic operation, especially as modified. I think these valves are about $16., last I remember.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 14-12-2005, 08:36
Doug G's Avatar
Doug G Doug G is online now
Coach / Teacher
FRC #0701 (Robovikes)
We just used a standard off the shelf sprinkler valve that has a diaghram and is actuated by a knob manually or by a solenoid. The solenoids are supposed to operate at 24 VAC. But after some experimentation we found a single spike relay connected to just 12-13 VDC on the robot works fine. At first we thought we were going to have to configure an additional power supply, but in the end we didn't Now to rig up a motor to a compresser to charge our two large tanks - hmmm, might need a deep cycle marine battery as well.
I heard about Elk Grove's (1147) T-Shirt Launching robot at the Kings game - if you do it again let us know (not ride your coat-tails, but to promote robotics of course) we'd be happy to join you out there.
Unread 14-12-2005, 10:24
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
The request for future performances has already been placed! We now wait with baited breath. If we do get an invitation to do it again, we will most certainly request that you join us. Promoting FIRST Robotics is way more important than promoting just our team! Besides, a little competition on the court is way more fun, and better exposure, than performing solo.
BTW, did you follow the link and see the short video I posted a few frames back? You should have seen the smiles on these kids faces after they came off the court! <--- That's what they all looked like.
In fact, here is a link to a picture I snapped as they were exiting the court. It doesn't even do justice to what we saw once they got off the court and thought about what they had just done.
Unread 07-01-2006, 18:26
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
When did you make this?
Unread 07-01-2006, 18:52
billbo911's Avatar
We built the t-shirt launcher over the summer. It is mounted on our 2005 'bot.
I guess we must have had a little premonition about the need to learn about launching stuff!!
Unread 07-01-2006, 19:13
Doug G's Avatar
Coach / Teacher
Ok so we figured out the game like back in Sept and built our robot early - so when do the competitions start? - we're tired of waiting already!!
You can see it shooting a ball at our website...
Unread 07-01-2006, 20:06
FRC #0701 (RoboVikes)
Yeah... we just gotta make some minor modifications... we're gonna swap out the big air tanks with the air tanks in the kit.
Team 701
Unread 08-01-2006, 18:44
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
The only problem with an air cannon and the 2006 game...can you make it launch slow enough as to not break rule <S01> No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph)...
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 08-01-2006, 18:55
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
I digg that! That is awesome, hey you guys have a proto of some sort
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 08-01-2006, 19:02
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I think if you could use the limited air pressure to get a ball to go that fast you should get an award. It would be very difficult would it not? Limited to two air tanks.
Unread 14-01-2006, 15:42
SenseiSkins's Avatar
SenseiSkins SenseiSkins is offline
Bow to your SENSEI!
AKA: Garrett
FRC #0177 (Bobcat Robotits)
Team Role: Student
SenseiSkins is an unknown quantity at this point
that is gorgeous i gotta get me one,
sphere bot Veselin Kolev Technical Discussion 36 03-03-2005 00:03
kit bot wireing sirbleedsalot Electrical 5 27-01-2005 17:59
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Team 1072 (Harker Robotics Team)'s bot: Tork AlbertW Robot Showcase 8 19-02-2003 13:19
Check out ma bot! Devil's Kid 3D Animation and Competition 1 09-02-2002 13:40
