Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
Unread 14-12-2005, 21:47
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Input On Steel chassis w/wood inset
Originally Posted by Henry_Mareck
I don't think the kit frame is low enough to the ground for my liking.
It's all in how you use it. 121 used the kit frame in a "low rider" conifguration with much success.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 14-12-2005, 21:51
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
If you can't weld Al (skill-intensive), and you don't want to use 80-20 (expensive)...
Rivits! Pop rivets are good when used correctly. I love pop rivets. You can be pop riveting after a $16 investment at your local hardware store.
And for wood - that is nature's composite. Most lumber only has the fibers (that resist tension) running in one direction. That's seen in the grain. But you can get plywood with the sheets running 90 degrees from each other. When used correctly, in the correct applications, wood is good.
Basically - there is no correct answer - each application, each material, and each design need to be considered and evaluated based on what's important to you. That's engineering...
Edit:
Oh yeah, on the kit frame - if you worry about it's rigidity, take a sheet of plywood and put it inside the C-channels to give it a solid wood floor. Bolt that sucker down, and the frame is going nowhere fast. (But the kit frame is DARN nice... and more modifiable than it's given credit.)
Brian Graham
Unread 14-12-2005, 21:52
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
yes, the kit frame is a very solid start.
However, i think that we can put in the extra effort to create a personalized base that meets all the specifications we want it to.
I don't think the kit frame is low enough to the ground for my liking. does anyone know how much the kit frame weighs, anyway?
IIRC about 13lbs total. Pretty good if you ask me especially considering how easy it is to use to get started and how much abuse it can take and how flexible it is and that it is free! I know our team could never design and build a frame as light and strong and flexible as the kitbot frame with the resources we have.
There are lots of ways to "lower" the frame if you want to. Flip it upside down and make some aluminum pillow blocks and you can drop it to the ground if you wanted to. Flip it upside down and slap a couple of the new IFI 4" wheels on there an you should be pretty low.
BTW: How do you know low is a good thing this year? Since we don't know what the game is yet, low may be a bad thing.
Unread 14-12-2005, 22:03
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
I DO know (unintentionally) tipping your robot is allways a bad idea.
and we are not only not welding beacue its skill intensive, we just dont have a welder
however, if i tried it i would probably end up setting my hair on fire
Unread 14-12-2005, 22:25
Gdeaver Gdeaver is offline
FRC #1640
1/8" steel pop rivets, T6061 1x1x1/8" aluminum angle and a drill will give you a tough box. 1/4" furniture grade birch plywood is tough and light. To kick the plywood up a notch laminate a layer of 6 oz. S fiberglass on one side with epoxy or real go for it and laminate both sides. Strong, lite and can be done with common hand tools.
Unread 14-12-2005, 22:35
occra 23.
AKA: ryo
None #1481
slightly offtopic but while we're on rideheight, what is the minimum ground clearance most people would attempt. assuming the playing field is a completely flat surface or carpet. and using pretty solid tires not spongy ones or pneumatic ones. ones with very little give.
Unread 14-12-2005, 22:37
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd say probably at least 3/4 to 1", given that the floor might not be completely level, and you might encounter other unexpected obstacles.
For instance, you could have bottomed out on the HDPE triangles in the loading zones last year, without a bit of clearance.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-12-2005, 22:42
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
Still somewhat off-topic, but a quick technical question -- what are the wheels that 121 used made of?
Unread 14-12-2005, 22:46
They look like they may be Colson wheels.
Unread 14-12-2005, 23:34
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
We've used wood bases on all our bots prior to 2002 and they're been pretty durable and very convenient when mounting anything. But I decided to step away from wood if necessary to reduce weight.
As far as Aluminum Welding - We just had a complimentary TIG welding Class organized by Team 340 and it was an experience. It was alot harder than it looks.
Has anyone tried using this DuraFix stuff seen on TV and at trad shows? It's Aluminum brazing. I tried it on some easy butt welds and it seemed to hold up somewhat and can possibly used for small pieces with lower loads but I really had to crank on it to really break the first time weld I made.
This does require some practice with proper material heating and prepping but it may be an alternative if you don't have access to a TIG welder.
Just something to throw out there... It's a lot cheaper $40/lb of brazing rods from Durafix and only $8/ packet at harborfreight for about 8 -10 rods.
Let me know if you've tried this before.
Ellery
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
Unread 15-12-2005, 00:13
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Last year we designed for 1\2" and ended up with 3/8" since the tread compressed more than we expected. Anytime you have to reach high, you need a low center of gravity. On the otherhand, for 'First Frenzy-Raising the Bar' we had more than 6" of ground clearance, but placing the battery below the axle, helped lower the center of gravity.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 15-12-2005, 01:14
John Simons's Avatar
John Simons John Simons is offline
#0269 (Cooney Quest)
John Simons is a jewel in the roughJohn Simons is a jewel in the roughJohn Simons is a jewel in the rough
I think that you have an excellent idea with useing a steel frame, as long as you select the proper grade. Our team has been using a 4130 chromoly frame for the past few years and it has worked extremely well for us. First of all, it has a much higher modulus of elasticity than aluminum and therefore will deflect less in an impact let's face it that just tends to happen in these games. Secondly, it's fairly lightweight. I know that you thinking this probably can't be true, but it is. One inch square tubing with a 0.049" wall thickness is only about 18% heavier than 1" sq. aluminum tubing with a 0.125" wall thickness and has about 3 times the strength. Third, this will allow you to weld more easily. It can be welded with a standard MIG, although I do recommend TIG. Or if you're in a pinch or have electronics mounted on the frame it can easily be gas welded. If you want a real world example of where this material is used look no further than autoracing. Most roll cages are built out of this strong material and some vehicle frame are built with nothing but.
If you do decide to use this material you will have to do at least two things to ensure the longevity of the frame. Firstly, you have to paint or clear coat it because 4130 is highly susceptible to corrosion. And secondly I would recommend annealing the frame to reduce stresses that may have been introduced during welding.
Unread 15-12-2005, 02:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Chromoly is a bit expensive though and not every metal store stocks it.
Aluminum seems to be the material of choice for FRC robot frames. I don't like hearing "we don't have a TIG so we can't have a welded frame" I hear this far too often. What you should be saying is "we want a welded frame so we're going to find ourselves a sponsor or volunteer with a TIG" Don't say "we can't do it so we won't" say "we can't right now but we sure want to so we will find a way" We don't have a TIG welder, heck, we don't have any welder, but for the last two years we have had a beautifully TIG welded frame and we didn't pay a dime to get it done. There are people out there who can help you out, you just have to let them know your situation.
If you try to make a welded aluminum frame happen and you just can't find anyone willing to help you out with the TIGing, then try to design a bolted or riveted together frame. I bet it will work better than you may think.
Unread 15-12-2005, 19:05
in between teams
AKA: Luke Van Oort
Also, for any type of tube or sort of tubish frame, you can stiffen it with structural foam. Just spray it in and let it dry, and you have rigidity, however, I have no idea how much it costs/weighs. For other methods, look at the tuner aftermarket for sport compacts. A Civic or Lancer is about as stiff as tissue paper, but with proper chassis braces they can be stiffer than most sports cars. If you're dead set on saying "we have steel" then a steel tube or bar hammered flat at the ends with threaded holes drilled in and bolted to the kit frame can greatly stregnthen your chassis. Mind you, if you want shock factor I'd advise the material on page 3361 of the McMaster catalog, a bit hard to work with, and it can be hazardous sometimes, but it'll definatly get noticed.
Team 1219: 2009 - Mentor
Unread 15-12-2005, 22:14
Not2B's Avatar
AKA: Brian Graham
Ellery
Yeah, I wondered about that stuff. It's not great. I could break all the joint I made with some good impacts and twisting.
HOWEVER...
Real Al brazing (with the correct flux) is easy enough to do with tools you can pick up at Home Depo (or others). The joints I made a few years ago are still together, and that's after I asked the team to try to tear it apart (with no tools.)
But you'll want to practice, practice, practice... I also like to rivit joints as a back up - belt AND suspenders approach.
Brian Graham
which is better aluminum or steel???? SCYTE16 Kit & Additional Hardware 50 24-11-2005 13:35
