Go to Post Regardless on how you feel about any team--respect should be paramount. - MeGuttieri [more]
Unread 14-12-2005, 22:35
occra 23.
AKA: ryo
None #1481
Re: Input On Steel chassis w/wood inset
Originally Posted by Karthik
It's all in how you use it. 121 used the kit frame in a "low rider" conifguration with much success.
slightly offtopic but while we're on rideheight, what is the minimum ground clearance most people would attempt. assuming the playing field is a completely flat surface or carpet. and using pretty solid tires not spongy ones or pneumatic ones. ones with very little give.
which is better aluminum or steel???? SCYTE16 Kit & Additional Hardware 50 24-11-2005 13:35
