Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Unread 15-12-2005, 02:05
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Snow Machine Tracks
Background: Ok, my team (from Alaska) is trying to design a robot for a non FIRST activity. It will need to cover outdoor terrain, travel quite a long way (half mile at least), and travel in all weather (if there is any snow it will be well packed). There wont be that much in the way of restrictiosn as far as power sources (gensets should be ok), weight, etc. Just keep in mind we have to have a motor controller that can handle enough power for the motors. Our team will have a set of 18v Dewalts, and no real machine shop type tools other than a grinder, a wood bandsaw that we messed around with to make it cut metal, and a little drill press.
So this one sort of mentor type guy and his son came up with the idea that we should use tracks. Maybe snowblower tracks. Then they got an even "better" idea: lets take a snow machine track and split it and use that. The idea jus seems plain bad to me, but I cant really find the words to express my dislike for it. Anyone got thoughts? I just cant see how we could possibly get enough power to drive such a thing, and how we would ever be able to build a track drive system from scratch using a sawzall and hand drill. Anyone who has ever tried to make a sprocket using a sawzall and a welder (not that its not a fun way to waste a few hours) will probably know what im talking about.
Am I way off the mark on this, or is this really not a good idea?
Unread 15-12-2005, 05:30
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Snow Machine Tracks
robotcombat.com used to sell some snow blower tracks (cheap because they were for a discontinued snow blower) but they don't appear to have them any more.
Team #519 used them in the '04 season. There was another team I saw that used them also. 519, as I remember, had problems with them. On the other hand, the other team looked to be using them effectively. The difference may have been that 519 used them like a tank would - IE full and only contact with the ground - while the other team had them on the front with regular wheels and tires on the back. I think they double rotated, something like the front treads on a PACBOT.
Unread 15-12-2005, 07:09
It doesn't sound like a totally bad idea to me. There are significant problems to face, one being just cutting the track. I don't know what the size/weight of your vehicle but you need to consider that a tracked device with no other steering requires a lot of power for turns. As for speed controllers, I believe IFI does make another line of controllers designed for a higher voltage. If they don't, search around, there are other companies building controllers. In your application, tracks may be better at distributing the weight of your vehicle on the surface it drives across. The down side of using tracks is that they fall off if the design doesn't account for the side forces in turns. Once you lose a track, you're done. Obviously, there are designs that keep all of these issues in check and work perfectly OK. I wouldn't turn down the idea just yet. A little investigation is in order. BTW, where exactly is the competition going to be held? I spent a few days around Anchorage this summer.
Unread 15-12-2005, 10:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
You don't have to use metal snow machine tracks - there are also rubber tank tracks. The only downside of these is that they are a bit on the expensive side. Here is a picture of them from the 7-Up vending machine that was made by M5 Industries (a.k.a. the Mythbusters crew).
Photo from: http://www.m5industries.com/html/portfolio/7up.htm
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-12-2005, 11:40
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
You can try what we did last year. Chain.
http://www.wcsrobotics.com/multi.htm
K.I.S.S
Keeping It Simple Stupid
Unread 15-12-2005, 18:48
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
What about snowmobile tracks depending on how big the bot has to be.
if not my next suggestion would be try to argue the snowblower treads.
MechWarriors 573
Unread 15-12-2005, 19:00
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
If this is a FIRST sized robot, snowmobile tracks would probably be too big/heavy. I'm sure you can find various sizes and weights.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 15-12-2005, 20:32
Andrew Blair's Avatar
FRC #0306 (CRT)
Hey, with experience from the one of worst snowbelts inside the snowbelt(Buffalo beats us), you don't need tracks, and considering your resources would be better off without them.** In my opinion**. I also think treads look cool however. Here's the dealio. We own a snowblower with heavily treaded wheels that have navigated the deepest snow with relative ease. They are a heavy tread (3/4" knobs) but they would be far easier to turn, cheaper to obtain, easier to implement, be capable of a higher rate of speed, and be easier to maintenance than a comparable tread system. And as it is, you said that the trails would be packed, so it shouldn't be a problem.
<< Similar to this. You can get lots of different treads, and their pretty cheap too, considering a track.
-Sir Francis Bacon
-Albert Einstein
Making a smoke machine forcefully blast out the smoke. sanddrag Technical Discussion 16 18-12-2005 23:46
Mill Suggestions? phrontist General Forum 29 27-02-2005 14:00
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
