Go to Post Robotics season has monopolized my time for the past several weeks so I have not been keeping up with Segway news lately - Stu Bloom [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 15-12-2005, 15:25
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: No Mabuchi Motors in '06 kit?
Originally Posted by coastertux
If fasteners aren't allowed, how are we going to hold the robots together? The frame uses bolts and I would consider bolts fasteners. :b
It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder.
Pete Kieselbach
Unread 15-12-2005, 15:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Horray for knowing CAD, and CNC programming in the upcoming year.
Good luck people.
How do you fix it at competitions though??? Is welding considered a fastener?
Unread 15-12-2005, 15:35
Originally Posted by Jay TenBrink
I'm afraid that rubber bands cannot be allowed since they could also be used as fasteners. As has been pointed out earlier, fasteners will not be allowed this year....
Doesn't the alleged rule just prohibit threaded fasteners?
Unread 15-12-2005, 16:00
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
J-B Weld? Although I prefer this, the elevated temp cure makes it tough to use for quick repairs in the pits
Unread 15-12-2005, 16:32
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Looks like we're going to pull out our Handlheld Ultrasonic Welder. It's been collecting dust since Clark and DJ graduated.
AB
Unread 15-12-2005, 16:43
Best Available Data
FRC #1778 (Chill Out!)
Good luck people.
Ah ha! I knew there was a reason a few team members got certified to use PlasmaCAM (basically a CNC machine with a torch) and to weld.
Unread 15-12-2005, 16:52
Andrew Blair's Avatar
FRC #0306 (CRT)
If this does end up in the 2006 rules, CD is in trouble! These are threads, and they are what hold the community together...so CD must be a threaded fastener right?
-Sir Francis Bacon
-Albert Einstein
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
How many Van door motor(s) come with the kit? Ken Leung Kit & Additional Hardware 7 07-01-2003 21:40
