Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 15-12-2005, 17:48
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
Drilling Lubricant
I would like to know what type of cutting/drilling lubricants work best in FIRST applications (i.e. drilling in aluminum, drilling in steel, milling...) What type of ventilation is needed with these products? Where do you purchase them?
Thanks for your help.
Jason Kixmiller
Unread 15-12-2005, 17:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Drilling Lubricant
You should be able to use pretty much any kind of cutting oil.
I've mainly used Tap Magic. It works well for tapping, drilling, or whatever other things you might be doing.
No ventilation needed, either.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-12-2005, 18:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For aluminum, there's this stuff called A9 (I think that's what it is) that is green in color and it comes it a little rectangular can. Tap Magic is good but the smell gets to me after a little while and I don't like it on my hands.
My personal favorite for aluminum and/or steel is what is commonly used in CNC machines. It is some sort of water soluble oil. I believe you are supposed to mix something like 2 parts water to one part oil. The oil is motor oil colored but when mixed with water it is sort of a cream colored. I've seen it come in a blue jug, although I don't remember the name of it.
One other thing I used once for cutting aluminum with a good amount of success was RIDGID brand oil (that I think was made for pipe threading). It was like night and day, almost like dull blade vs sharp blade. Home Depot would be the only place that has it if they still make it; it was quite a while ago.
In a pinch, almost any oil is better than no oil. I've used motor oil quite a few times for steel. Smells really bad, but works better than nothing. Even liquid wrench works to some extent, although you'll want to watch out for fumes.
Unread 15-12-2005, 18:07
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
EDIT: Others have pointed out safety issues with WD-40, so i'm no longer recommending it here.
Unread 15-12-2005, 18:41
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
I think i may be talking about the same stuff as sanddrag but it is a bright lime green in color and works great. As far as i know no ventilation is needed
MechWarriors 573
Unread 15-12-2005, 19:01
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
WD-40 is definitley the simplest option, it is easy to find and purchase.
Works great for us too.
Unread 15-12-2005, 19:34
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
believe it or not, in SAE, we use automatic transmission oil (we have a free supply, since our shop is right by the campus bus maintenance station). it works great going through steel, aluminum, iron, etc. the only downside is that the whole shop smells like a burnt out transmission.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 15-12-2005, 20:22
IWIWAB
Thanks for the responses...where do you purchase the green stuff?
WD-40 is a pretty easy solution that I have used in the past - one word of warning, though, fumes from it are not to be inhaled (written on the can) so I am hoping to avoid it.
Thanks again for the info.
Unread 15-12-2005, 20:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I would strongly advise against using WD-40 as a cutting fluid.
WD-40 = flammable.
Most metal lube juices for cutting/milling is not flammable.
There is a whole science behind cutting fluids.
Don't use an all in one fluid like WD-40 as a cop out, or bad things may happen.
I was told we use something with the nickname gogo juice, but I'm not sure the real name.. Maybe Alumatap?? That's more for aluminum I'm guessing from the name though.
Unread 15-12-2005, 20:41
TechnocratiK TechnocratiK is offline
AKA: Patrick Diez
None #0296 (Northern Knights)
TechnocratiK is an unknown quantity at this point
For some reason, everyone on my team complains to me that the term "coolant" is preferred over "lubricant" (but I can't imagine why). Anyway, the coolant we use is ESSO Cutwell (I can't remember which kind - 40 or 45 maybe?), which can be bought in 4-litre bottles and is usually dissolved in water before use, meaning that one purchase should last at least a whole season.
TechnocratiK out.
Unread 15-12-2005, 20:59
occra 23.
AKA: ryo
None #1481
well technically a good "lubricant" would keep you from cutting in as the drill bit's edge would only slide across the surface. a coolant keeps the tip cool
Unread 15-12-2005, 21:02
IWIWAB
Where can you buy these products???
Unread 15-12-2005, 21:21
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Like so many other problems, the real answer is "it depends." Are you going to be applying it by hand, or using a misting system, or flood cooling? Are you looking for something to help with just drilling a few holes, or to help with thousands of holes and tens of hours of heavy-duty milling operations? Are you going to be hand-tapping everything, or using a tapping head on a mill? The best answer for one situation is not necessarily the best for another.
For my shop at home, I buy a gallon at a time of Mobilmet water soluable cutting oil. There are several equivalent medium-duty soluable oils that will do just as well. This class of lubricants will provide good general-purpose solutions that will cover the majority of typical situations you are likely to encounter when building a typical FIRST robot. If you are going to be applying the lubricants with a misting system, I would look for something heavier such as one of the sulfurized heavy oils (but don't use a sulfur-based oil on brass, bronze or copper unless you don't mind stains). The gallon may seem like a lot, but it is great to have a supply that lasts a while (and it is a lot cheaper by the gallon - or even five gallon - jugs than in the little 3-ounce bottles).
Check pages 689-692 of the Enco 2005 catalog (or just about any other industrial supplier - MSC, Grainger, McMaster, etc.). They carry all sorts of industrial lubricants, cutting oils, etc.
I would NOT recommend using WD-40 for anything other than a last resort, once in a while solution. It is a great penetrating oil for freeing stuck parts, but it is not intended as a cutting oil. Because it is so thin, it has a lot of volatiles that will evaporate very quickly, thus it should not be used in areas that are not very well ventilated. It will also leave residues on the work surfaces that can be a real pain to clean off later.
-dave
Unread 15-12-2005, 22:01
AKA: Patrick Diez
Good point. Finally, I have reason to call it lubricant and not be laughed at. Thanks!
TechnocratiK out.
Unread 15-12-2005, 23:31
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Not sure about your general hardware store, but in terms on online dealers -
For buying by the pint
Or by the case
That at least gives you a picture of what to look for in stores.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
drilling into sprockets greencactus3 Technical Discussion 18 06-11-2005 15:06
Who is drilling holes this year ?? shyra1353 General Forum 28 02-12-2004 03:22
Advice on drilling through hardened steel? ThetaDot Technical Discussion 10 28-02-2004 05:18
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
drilling that chiaphua gear ahecht Motors 8 06-02-2002 01:23
