Go to Post If sponsors are only interested in blue banners and trophies, then they don't get it. - Taylor [more]
Unread 15-12-2005, 18:09
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
Re: Which treads have an advantage?
Originally Posted by sanddrag
We tried cutting it on the bandsaw and the blade mostly just tried to suck it down/in. Then, we thought maybe we could turn it over for better results, but then it wouldn't slide on the saw table. So, we put it upside down (grippy side toward the table) and set it on top of a piece of paper on the table, and then it was able to slide easily and the saw cut it to perfection. It came out a perfect cut! Try using a fine blade meant for cutting metal so it doesn't catch the rubber and pull it down.
Thanks! I'll make sure we do that this year -- that'll be so much easier than cutting that stuff by hand.
Tank treads, how we roll plutonium83 General Forum 6 08-01-2006 14:51
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
where to buy treads? illumanat'i Technical Discussion 11 11-01-2004 22:05
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
