Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Unread 15-12-2005, 16:29
MarkVH's Avatar
MarkVH MarkVH is offline
AKA: Mark VanHaitsma
FRC #0288 (RoboDawgs)
MarkVH is on a distinguished road
Connector for gyro chip
Does any one know where a connector for the BEI AQRS-00064-109 gyro can be found?
We are trying to use the old gyros from 2001 for programming training.
Unread 15-12-2005, 19:43
Re: Connector for gyro chip
ouch! I think they came in the kit of parts, and were oddball connectors.
Last time I wired up one of the old gyros I chipped the connector houseing back a little with some wire cutters, and soldered three wires right to the pins, with heatshrink over the exposed wire.
Unread 15-12-2005, 20:03
Andrew Blair's Avatar
FRC #0306 (CRT)
Ooooh boy. This is exactly where we were about two weeks ago. Try to look again. I know, I know, but ours showed up right after I had given up on it. Ken's method was my last resort, though right up my alley. You know, hack slash, buy a new one, hack slash some more...
-Sir Francis Bacon
-Albert Einstein
Unread 15-12-2005, 21:58
MarkVH's Avatar
Thanks for the replies. I emailed BEI asking where I could find the connectors and they said they no longer had them. They didn't suggest places to look.
Unread 16-12-2005, 11:01
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Hey Im not sure if you have seen these or not but i uploaded the original spec sheets for both gyros.it includes the name and part number of the connector which is NOT made by BEI but instead is a standard part by another company. and also according to the spec sheet they are NOT or ever were included inthe KOP.
http://www.chiefdelphi.com/forums/pa...le&paperid=561
-Osc
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 16-12-2005, 15:10
The connectors were included in the KOP for those years. We are still using ours.
Unread 16-12-2005, 15:41
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Never seen them in our kits. we just soldered a pwm directly to the pins and filled the empty space in between with a hot glue gun, it keeps everything in place well.
Unread 16-12-2005, 20:51
FIRST has given out two different versions of the BEI Gyro.
I could be mistaken, but I think the connector used on the older one went end-of-life (discontinued) by the manufacturer, and that is why they had to change the design of the gyro to use a different connector.
Unread 16-12-2005, 21:36
You should be able to use 2 PWM cables to connect to the pins. Just check the spec sheet to see where each wire should go.
Unread 16-12-2005, 22:33
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The connector is a Delphi-Packard connector. Since I am on leave from Delphi, I don't have the master Packard book handy any more. I think the connector is available from some sites that sell ones and twos of the Packard connectors.
Hmmm....
Let me think about it. I may be able to come up with the part number...
...stay tuned.
Joe J.
Team #88, TJ2
Unread 17-12-2005, 15:16
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Hmmm....
...stay tuned.
Joe J.
the part numbers are in the spec sheets i uploaded
Unread 22-12-2005, 23:59
MarkVH's Avatar
Thanks for the part numbers.
Optical Mouse Navigation phrontist Programming 60 14-03-2005 21:48
What RAM chip has... MarkF Chit-Chat 4 24-03-2003 20:39
chip motors next year? JamesJones Motors 3 15-05-2002 22:38
Is any team using the gyro chip? Ragin_Kage Kit & Additional Hardware 4 10-04-2002 12:11
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
