Light and Line Following Sensors
I got Light Sensor Kit and Line Following Sensor Kit. The sample code for these sensors output to screen only. Is there sample code that have the sensors control the motors? Should I get another light sensor kit and should I get two ultrasonic range finder kits? The optical shaft encoder kit and the ultrasonic range finder kit are out of stock at both Radio Shack and VEX Labs.
Re: Light and Line Following Sensors
There is some sample code for the old Robovation kit that can help you:
http://www-education.rec.ri.cmu.edu/robot_builder/ Click on Programming and there will be line tracker and Light/Dark demonstration code under "IR Reflective Sensor" Last edited by Mark McLeod : 15-12-2005 at 22:02. |
| Optical Sensors Used as Encoders? | uvabrad825 | Technical Discussion | 22 | 03-05-2004 13:22 |
| Getting Fancy with Sensors | FadyS. | Programming | 30 | 10-03-2004 15:02 |
| Why not analog sensors?? | gnormhurst | Programming | 16 | 07-03-2004 16:14 |
| Line Sensor hookup | Dinush | Electrical | 9 | 15-02-2004 23:13 |
| Line sensor wire gauge questions | Dinush | Electrical | 6 | 13-02-2004 18:41 |
