Go to Post Brandon is my hero :) - Cory [more]
Unread 15-12-2005, 22:02
Umm Errr...
Welder advice needed
Our team has limited money but we would like to buy a welder for use with aluminum and steel. We don't have the money for a TIG or anything like that. I have seen a few MIG packages in the $4-500 area which look decent. What kind of quality can be expected from this sort of setup? Will it work for FIRST purposes?
1139 Alumni
Unread 15-12-2005, 22:35
REVving up for a new season
FRC #2848 (All-sparks)
Re: Welder advice needed
yes you can get a nice MIG for $400-$500 but most will have little or no aluminum ability. I personally own a Miller 135 which i bought for $445 and have been extremely happy with it. As for applications in FIRST your team needs to decide if you are willing to limit your building materials to match you welder.
There were two excellent threads a while ago talking about welding.
http://www.chiefdelphi.com/forums/sh...ad.php?t=38730
and
http://www.chiefdelphi.com/forums/sh...ad.php?t=30679
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 15-12-2005, 22:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Whatever you do, do not buy a Harbor Freight welder. They pretty junky and quite unsafe in some ways.
I've been looking at this Lincoln welder on eBay http://cgi.ebay.com/LINCOLN-SP135T-M...cmdZViewIt em
and this aluminum kit for it http://cgi.ebay.com/LINCOLN-K664-2-A...cmdZView Item
This seems to be the cheapest way to go. For how well it'll work, you can bet it'll be better than a Harbor Freight, but I don't know just how good it will be. It seems to be a pretty nice little setup. For doing aluminum, I've never tried but everyone says you should do it with a TIG, but it can be done with a MIG. As for actual experiences with the MIG and aluminum, I haven't heard much beyond "it can be done"
I've also seen rods made for stick/arc welding aluminum, but I've never tried it and haven't heard anything about them. The same goes for oxy-acetylene welding aluminum.
This may be obvious but try to get the highest current welder you can with the money you have. You will always have a welding job that could use more current, especially when it's aluminum.
Unread 16-12-2005, 01:26
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I don't think you're gonna be able to weld aluminum with a MIG Welder. And I believe that you need an inert gas when welding aluminum.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 16-12-2005, 06:38
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Keep in mind that you'll also have to pay for the tank of gas in addition to the welder. You can either rent them for a monthly fee or buy the tank outright.
I own my tank outright and I bought the largest one I could get. Running out of gas in the middle of welding is no fun. The tank cost me $160 filled, and refills are $25 where I go. Since I may not use the welder for a few months at a time this was the best route for me. Smaller tanks are cheaper to buy but the cost of getting them filled isn't much cheaper.
If you're going to be welding aluminum and steel you'll need two different tanks. You'll need straight argon for aluminum and a mix (usually 75-25) for steel. I would not do flux cored welding since it isn't as neat.
You'll need a cart or something to secure the tank also. I elected to buy a cart but with the welder you could easily make one yourself.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 16-12-2005, 07:47
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
You may consider contacting a local welding supply company to see if you can borrow or rent a TIG welder. (Have them list the expense as a donation & put them down as a sponsor). For FIRST a tig welder is really the way to go. We borowed a welder for the 6 week build period for 4 years before we had enough money to buy the one we wanted. A Miller Dynasty 200. It is a very nice machine for FIRST purposes, easy to setup, easy to use. We have 2 small tanks and try to keep both filled. When one runs out we swap tanks & get the other refilled. A few years ago we ran out of gas in the middle of the night and had to wait until morning to get a refill.
good luck
Unread 18-12-2005, 12:23
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
so whats the difference between a TIG and a MIG ?
Unread 18-12-2005, 13:40
A google search is a great way to find out but simply speaking, a MIG welder has a spool of wire that it feeds through a hose and out the tip of a "gun" when the trigger is pulled. The wire is made electrically "hot" so it arcs and melts away as it is being fed out of the gun. It requires one hand to operate. The wire is very small diameter (about .030") A TIG welder has an electrode that makes the arc. Then with the other hand, a relatively larger rod is fed into the arc by hand.
Unread 20-12-2005, 08:56
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
That is deffinately not true. I have one I got form Harbor Freight and it works awesomely.(if that is a word)
It is the 100$ flux cored welder.
I get beautiful welds and great penetration.
Unread 20-12-2005, 11:45
Okay, I'll partially take that back and say I have never used one. But I have tried out there helmet and the shade is not uniform darkness and that scares me, a lot. Inside the welder, all the drive parts are plastic, not aluminm like a Hobart or something. Getting parts for them I've heards is very hard. The wire is always live whether you are pulling the trigger or not: very dangerous and difficult to get close to the workpiece before starting unless you use an autodarkening. But, they are affordable. BTW, ever tried aluminum wire with an HF welder? Just curious. I want to see what's the cheapest way to effectively weld aluminum without borrowing equipment or having someone else do it.
Unread 20-12-2005, 16:51
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I've never had problems with it breaking or needing parts. Yes the wire is always live which I hate too.
Nope never tryed akuminum wire on it. Don't have the money or will to.
I have one of their helmets too and it works fine, I use it for both tig and mig and I have never had a problem. Bad lense maybe?
Unread 20-12-2005, 17:26
AKA: Jason Hartmann
It would be safe to say that if that $100 welder isn't able to be set up or converted to run shielding gas then it's not able to weld aluminum. The lack of heat control with welders in that price range would also be another factor when dealing with aluminum.
Unread 20-12-2005, 17:44
No offence but how much is your eye sight worth to you? Because Ipersonally wouldn't feel comfortable in a 40 dollar piece of plastic made in china, my sight is worth far more then that to me. Remember you get what you paid for.
As for the wire welder, i am sure it would work fine on small stuff but try something with some thickness and i think you will find that it leaves much to be desired.
Remember folks MIG welding is just sending dc current through metal, the place where the circuit connects is the point of most resistance which is wear the heat comes from, it is a very simple process.
Unread 20-12-2005, 23:06
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
Also to follow up on Greg's note - In order to use a TIG welder on Aluminum it needs to be AC - The HarborFreight Tig welder is only DC and does only Steel applications anyways.
I recently tried TIG welding and it takes alot of practice to do it correctly. also The Miller 200 Jason mentioned rocks. I was going to buy one myself but ended up buying en enclosed trailer to haul robot stuff (and other things) instead.
It's not quite a wise investment if you're only using it less than 6 weeks a year.
Ellery
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
Unread 21-12-2005, 23:27
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Well the helmet may have cost 40$ but that doesn't mean it isn't good. When i say i haven't have any problems with it I mean What i said pretty much. When i am welding with it it has a fast reaction time and I almost always have it on the darkest shade which is around 14 on it, and I haven't had any problems. S o i guess your right i do get what I paid for; a good welding helmet.
The welder that Rees mentioned earlier is the one we have at school and we use it for everything. It has never failed us and is really versatile, you can hook it up to 120V, 240V or 208V(one or the other), then 408V or 440V(same thing).
Though the price is around the mid 2500$ range I would say it is a must buy if your gonna do alot of welding.
Need Advice on approaching big corps. about money Ben B Fundraising 8 05-04-2004 17:49
Expert advice needed!!! punarhero Technical Discussion 16 01-03-2004 11:34
Dirty Birds need advice DirtyBird213 General Forum 13 11-12-2003 21:24
Rookie advice for the Championship Event Carolyn Duncan Championship Event 2 07-04-2003 17:57
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
