Go to Post Thank goodness there are people in this world who refuse to let physics and calculus ruin a good story. - Richard Wallace [more]
Unread 17-12-2005, 13:29
ronmarkum ronmarkum is offline
FRC #1750
ronmarkum is an unknown quantity at this point
Making the gears drive - motion
Does anyone know how to set the constraints on spur gears generated in Design accelerator so that when you rotate-move one gear it drives-rotates the other? Using inventor 10 release.
Unread 17-12-2005, 13:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Making the gears drive - motion
Go to the constraint tool, select the Motion tab, select your axes of rotation, and set your ratio. Make sure you set the relative direction of rotation too (for gears-opposite directions, for sprockets-same direction).
Unread 17-12-2005, 14:26
FRC #1750
The gears seem to be over constrained and won't move. How do you suppress the constraints that inhibit the rotation? When the gears are created by Design Accelerator they are automatically generated with a boat load of constraints. As a new user I am not familiar (yet) with all these special constraints. Any suggestions?
Unread 17-12-2005, 15:13
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
seems thats an Inventor 10 thing (since u mentioned the design accelerator) i havent had ton of time to really mess around with it... but constraints are only in assemblies, not parts. sooo once you create a part such as a gear it has its own IPT. remove it from your current assembly and re introduce it into the assembly, at this point it should have zero constraints. now just apply 2-3 contraints ( constraint on the axle it rotates on, constraint of position along the axle, and a constraint for rotation with other gears).
I maybe wrong
-Osc
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 17-12-2005, 20:11
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Did you try un-grounding the first gear and suppressing the Gear Meshing constraint in the gear model? Those were the culprits when I tried it.
Pete Kieselbach
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
Gear Making Information Alan Ing Technical Discussion 14 29-10-2001 21:08
