Go to Post Remind me to wear my kevlar vest to any event you're at. - Andrew Schreiber [more]
Unread 18-12-2005, 17:34
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
Sprockets in a Triangular Arrangement
What are your thoughts on using a single piece of chain to connect three sprockets placed at the corners of an equilateral triangular? Is this feasible? I know that there will be less surface area contact between each sprocket and gear, perhaps resulting in greater stress on the sprocket, but do you think this would work?
(I did a quick search on this, but came across nothing - please lead me in the right direction if anything already exists on this. Thanks!)
Unread 18-12-2005, 17:47
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Sprockets in a Triangular Arrangement
Errmm, what exactly are you trying to do with this chain assembly?
-Sir Francis Bacon
-Albert Einstein
Unread 18-12-2005, 17:48
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
It depends on the ratio between gear radius and triangle side length...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 18-12-2005, 17:55
evolution's Avatar
Team Role: Student
Here is a visual of the sprocket arrangment. The approximate ratio between the smaller and larger gears is 7:32.
The intended purpose is to have two dewalt/CIM setups (the two smaller gears) leading to a sprocket attached to a wheel (this is the larger sprocket). Thus, rather than having two large sprockets and two small sprockets in pairs, I'm trying to see if I can get away with one large sprocket and two small sprockets.
Name:	sprocket arrangement.png
Unread 18-12-2005, 18:00
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
There are certain rules of thumb like the chain should wrap the sprocket approximately 120 degrees. These all point to the fact that the small sprocket is under the most stress. I think that you can make it work, you might have to use larger sprockets to spread the force across more teeth, or have idler sprockets push in on the sides of the triangle to cause the chain to engage more teeth. You could use stronger, heavier, more expensive sprockets and chains. Each problem has many solutions, but possibly only one will work when you factor in the rest of the issues.
This website might give you some ideas:
http://www.roymech.co.uk/Useful_Tabl...ler_chain.html
Edit: I was posting while you were posting. The small sprockets will endure the most stress. If you add an idle sprocket between them and force the chain down, you might be able to have the small sprockets engage one or two more teeth. This will spread the force across more teeth and reduce the possibility of failure. Unless you analyze the actual forces, it is difficult to know how close you are to failure.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 18-12-2005, 21:02
FRC #0306 (CRT)
It's doubtful that you would have any problem with this setup, though with the drivetrain config. I would imagine you ending up with a more obtuse isoceles triangle. However, we used a similar chain route before in our drivetrain, using #25 chain, and never had a failure. With an 10 tooth sprocket, and about 70 degrees of chain contact, we never had a problem. Not saying it can't happen though. However, as was said above, by mounting small idlers in the middle of the sides of your chain triangle, you will increase reliability and accordingly chain wrap. These idlers, if adjustable, also make it very easy to tension your chain. Which is a good thing.
-Sir Francis Bacon
-Albert Einstein
Unread 20-12-2005, 17:42
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
This is a matter of some debate, but the rule of thumb I usually follow is that there should be almost 180 degrees of wrap around all driven or driving sprockets. While your design would work, adding an idler or two would help (a) decrease the load on each tooth, (b) decrease the likelyhood of the chain skipping, and (c) give you a good place to put in a chain tensioner (since the chain will loosen as it wears).
Zan Hecht
Unread 21-12-2005, 17:12
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
That is almost identical to the concept we used to drive our arm with 2 F-P gearboxes last year. See the linked images:
http://www.joemenassa.com/Images/ROB.../IMG_5997.html
http://www.joemenassa.com/Images/ROB.../IMG_5812.html
This worked fairly well, although our arm application was low rpm, and a drive application would likely be higher. The idler pulley is key to getting enough chain wrap so that you don't skip teeth under high load. When designing your idler, be sure to make it adjustable so it acts as a tensioner as well.
Good luck with your design, and have fun!
Rob
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
chain ridding up and off sprocket problem... davidhoare Technical Discussion 4 04-02-2004 10:13
Roller Chain Based Three Speed Transmission Madison Technical Discussion 11 09-01-2004 16:40
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
