Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Unread 19-12-2005, 00:56
CraigHickman
Posts: n/a
Inventor Help
A little problem-
I just got inventor 10 installed, so I tested it on the admin account on my comp. It worked great (I love it, by the way), until I signed into my normal account to try it out. I started up, no problems. Once I tried to open a new blank part, it sort of froze for a few seconds, and the program crashed. I've tried this with nothing else running, and a bunch of other things, and frankly I'm stuck. Anyone have any ideas?
Unread 19-12-2005, 01:08
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
Re: Inventor Help
How much memory do you have?
Are you using Windows XP,and if so, are you using the "switch users" function?
I believe that if you left your admin account open, and switched into your other user account (thus, without logging out of admin), more memory would be consumed. With less memory available to Inventor, you could end up crashing.
Unread 19-12-2005, 01:10
CraigHickman
Posts: n/a
Re: Inventor Help
I have 4 gigs of ram, so it's not that.
I also logged out the admin completely.
Unread 19-12-2005, 10:27
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Inventor Help
Originally Posted by 114ManualLabor
A little problem-
Did you try:
1. restarting?
2. install the updates & service packs?
3. try logging in as admin and running Inv. again?
Pete Kieselbach
Unread 19-12-2005, 14:51
CraigHickman
Posts: n/a
Re: Inventor Help
I tried all of these, same results. Also, I decicided that I might as well send the error report to Autodesk. We'll see if that does anything.
[edit] I noticed another thing, this may have something to do with the problem (I'm not sure, but it's worth a shot). Under the admin account, the inventor icons are normal, with different icons for each type of file. Under my normal user, however, the icons are all the inventor icon, the one that the program exe is. Might this have anything to do with it? [/edit]
Unread 20-12-2005, 04:46
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Inventor Help
Very odd.
I am having this exact problem, only in Inventor 6.
It's incredibly frustrating, as I used it a couple weeks ago and it worked fine, but now nothing I do works.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-12-2005, 10:08
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Inventor Help
When you installed it, Inventor might have asked you if you wanted to install for the current user only or for everyone on the computer. It might have been that you installed just for the Admin account (being where you would install it and the default option) and it freaks out for other users.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 20-12-2005, 13:53
Cory's Avatar
AKA: Cory McBride
Re: Inventor Help
If you install it for admin only, it should not open at all and give you some sort of error message on any other account.
At least that's what windows does for other programs...
2001-2004: Team 100
Unread 06-01-2006, 01:50
midgetcuber's Avatar
midgetcuber midgetcuber is offline
AKA: Rachel Fong
FRC #1072 (Harker Robotics Team)
midgetcuber is on a distinguished road
Send a message via AIM to midgetcuber
Re: Inventor Help
Inventor 10 keeps crashing on my laptop even when I'm not running any other programs, and I've installed all of the service packs. It usually crashes when I open a new part, but sometimes it will work for a few minutes and crash when I save or switch out of sketch mode. The weird thing is, it worked perfectly before I registered it. I'm going to try reinstalling on a desktop next...does this seem to be a widespread problem?
Unread 06-01-2006, 01:55
1075master's Avatar
1075master 1075master is offline
SLEEP IS POINTLESS!!!
AKA: John Nelson
FRC #1075 (Sinclair Sprockets)
1075master is an unknown quantity at this point
Re: Inventor Help
i have never had any problems with inventor.. our school has had many trying to get it to work on everyones computer and what not. the only thing different about mine is that it won't give me a registration code so its never been registered. the only annoying thing is the popup at startup that says would u like to register or run. but anyway i don't know how u can fix the problem.
2004 && 2006
-driver,head design, head build, secondary programmer
year >= 2007 && year <= 2009
-mentor in every aspect
Unread 06-01-2006, 02:12
Cory's Avatar
AKA: Cory McBride
Re: Inventor Help
I finally figured out my problem--I had outdated graphics drivers.
Worked perfectly for me once I updated them.
2001-2004: Team 100
Unread 06-01-2006, 18:06
CraigHickman
Posts: n/a
Re: Inventor Help
Yah, Turns out I had updated the graphics drivers the day I did the updates... So those help, for anyone else who encounters the problem.
