Go to Post Viva la geek! - Andy Baker [more]
Unread 21-12-2005, 13:39
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Dump Backup Battery
Does anyknow if its against the rules to replace the backup battery with a 7.2v powersupply? We want to dump the backup battery and run everything off our 12v battery.
Unread 21-12-2005, 14:11
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Dump Backup Battery
Originally Posted by Jack Jones
<R62> The 7.2V Robot Control backup battery must be connected to the Controller as described in the
Controller’s manual (the 7.2v battery should be charged to at least 7.0v before entering a match). As a
replacement for the FIRST supplied battery, any other 7.2V NiCad battery pack may be used.
Last year's rule - but don't expect it to change.
Unread 21-12-2005, 16:35
Trust me, there is a reason for the backup battery. I don't want to go into why FIRST introduced it. While the robot can run without it, no servos will work without it. Don't try running off just the 12V battery.
Unread 21-12-2005, 16:53
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
I believe, in addition to what Eric said, the backup battery is also to make sure the controller has enough power at all times (so it doesn't reset or loose contact with the OI if the 12v battery voltage drops).
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 21-12-2005, 16:59
That's part of what I don't want to go into...'Nuff said.
Unread 21-12-2005, 23:08
AKA: Dr. Brooks
no team (WRRF)
And, athough the rule clearly says that "any 7.2 volt NiCad battery may
be used" the technical inspectors refused our use of a larger 7.2 volt
battery in a prior year. If you come to a regional with a different battery
you should make sure that you also bring the FIRST provided one just
in case...
Unread 22-12-2005, 06:38
Elgin Clock's Avatar
FRC #0237 (Black Magic)
in case...
Or as all teams should, make sure you have a copy of the rule book with you during inspection (and at at all times).
Unread 22-12-2005, 07:20
And, athough the rule clearly says that "any 7.2 volt NiCad battery may be used" the technical inspectors refused our use of a larger 7.2 volt battery in a prior year. If you come to a regional with a different battery you should make sure that you also bring the FIRST provided one just
in case...
Gene,
I would have challenged that ruling. The training was pretty clear that any 7.2 volt battery was OK. The 7.2 volt battery insures that the RC proccessors stay active during 12 volt brownouts. The battery also feeds the radio modem and any servoes connected to the RC. IFI monitors your robot as you set up on the field and can tell the level of both batteries. If your 7.2 volt is missing or low they will alert you to replace the battery. Robots that have large current draw from the main battery will regularly pull that voltage down below the critical 7-8 volts needed to keep the RC alive so IFI came up with this change. You lose control of the robot for a brief time but you don't have to wait for reboot and initialization. Your partners thank you for having a charged and seperate 7.2 volt source for the RC.
Unread 22-12-2005, 12:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Al Skierkiewicz
Gene,
One other device that gets it's power from the "backup battery" that hasn't been mentioned in this thread is the CMUcam2. With the extra focus being placed on this device in CD right now, it would be good to remember that as well. I don't know for certain that we will be using this camera this year, but my guess is we will.
As far as using the 12v battery to drive a 7.2v supply as a means of eliminating the backup battery, forget about it. The only way to do this and still get 7.2v out of it even when the main battery drops below 7.2v would require a circuit with weight and size that exceeds that of the backup battery it's self.
Unread 22-12-2005, 15:39
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Huh? What is preventing you from doing it with an IC based buck/boost converter? Small surface mount IC plus an inductor and a few resistors is all I could see that would be necessary. I'm certinally no expert on power electronics, but I don't see what you would need that would be "a circuit with the weight and size that exceeds that of the backup battery".
Not that I would say its worth doing it, stick with the backup battery. If you are really worried about size/weight, there are plenty of suppliers of smaller premade 7.2V battery packs.
Unread 22-12-2005, 16:06
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Pardon me for asking but what do you think the advantage of using a 7.2v power supply would have been?
Based on the 5vdc Siemens inverters I use it seems like you just adding weight and volume to your bot. Am I missing something?
Pete
Unread 22-12-2005, 16:56
Timmyd's Avatar
Timmyd Timmyd is offline
HAHA...i like pi
AKA: Tim
FRC #0022 (Double Deuce)
Timmyd is just really niceTimmyd is just really niceTimmyd is just really niceTimmyd is just really nice
Send a message via AIM to Timmyd
we actually had our main battery terminal ripped off and we took off the back up battery and ran the 12v battery off the back up battery terminal it worked fine for us until we swapped out the ifi.
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
Unread 22-12-2005, 17:35
Retired
Many are missing the point that the keyword here is backup. Any electronics added to replace the NiCad and yet store enough juice to power the RC (ETC.) during brownouts is sure to be less efficient than the NiCad.
That is, you can't get something for nothing! Instead of having a pre-charged NiCad, you use power from the main battery, which is a net loss of power available at the start of the match. You'd also gain weight!
Unread 22-12-2005, 17:37
billbo911's Avatar
Again, the only advantage I could imagine would be gained by elliminating it would be a reduction of size and/or weight. I don't think it is possible to achieve both requirements based on what you are describing. (I don't mind being prooved wrong, it wouldn't be the first time.) The trick would be to have it supply enought power to keep alive all the devices that may be drawing from it when the input voltage drops to say 5vdc.
Now your talking. Just make certain it has the capacity to power all the devices that run off the battery.
Unread 23-12-2005, 10:49
We can't really answer this for a particulr robot but let us remember that there are robots (many robots) that have inefficient designs that do run the main battery down to nothing in a single match. I have had teams that were actually proud of the fact that they killed a battery every match. With that being said, a power convertor fed from the main battery is still going to fail when a current demand on the main battery causes it to go to a couple of volts during a shoving match. Even with boost buck convertors, a 10 volt swing on input will not reliably keep the backup power up at 7.2 volts. In this case, two voltage sources are the best solution.
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
