Go to Post The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..." - RoboMom [more]
Unread 12-11-2004, 17:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: Team 33 Four Speed Transmission
Thread created automatically to discuss a document in the White Papers.
Team 33 Four Speed Transmission by Jim Zondag
Unread 12-11-2004, 17:04
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: White Paper Discuss: Team 33 Four Speed Transmission
Thanks for posting this White Paper, it's been eagerly awaited by many of us. I'm sure this will provide a great resource to many teams.
Not to rush, but when do you expect the software paper to be available, I'd really like to check that out.
Again, thanks for posting!
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 21-12-2005, 14:45
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Question Re: White Paper Discuss: Team 33 Four Speed Transmission
Team 971 is building the transmission for machining practice, and we've found a part in the inventor files that isn't listed in the BOM. It is an extention comming off of gears C and G (highlighted by red arrows in the picture below), and no one on our team can figure out where it's comming from. Also, as indicated in the CAD files, the outer diameter of this "mystery part" is set to 3/5 inches...which is not a very common diameter, to say the least. Any help on this is greatly appreciated
-Nuttyman54 and Team 971
Unread 21-12-2005, 14:50
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
It is not an extension. Cut off a 1.375" piece of the 12T spur gear stock and turn the gear teeth off 1" of it. It is one piece. The other gear is bored and fit over the turned down section and welded on.
Unread 07-01-2007, 17:03
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
This link no longer works, would it be possible for someone else to post these files,
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 07-01-2007, 17:33
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
FRC #0033 (Killer Bees)
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
To fix the file, download the file and change the extention from .htm to .doc.
Unread 16-09-2007, 14:52
Aren_Hill's Avatar
Build Nifty Things
has anyone reliably shifted this transmission non pneumatically?
out team has developed the habit of never using pneumatics just because of the added weight from putting on tanks and possibly the compressor.
just wondering
also the link to the inventor files doesn't seem to be up anymore
A guy who likes robots.
Unread 16-09-2007, 16:46
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
just wondering
There have been several teams who have used servos to shift, and AndyMark does sell a servo shifting version of their shifter. However, while servo shifters often accomplish the task, many do not perform as well (ie shift as quickly or as reliably) although they are certainly more than functional.
The pneumatics vs. motor debate is an old one, and best saved for another thread, but if you did happen to have pneumatics on your robot, I would suggest using them to shift, but if you didn't it probably wouldn't be worth installing pneumatics just for shifting capabilities.
Unread 18-04-2013, 23:51
Jorge Ayala's Avatar
Jorge Ayala Jorge Ayala is offline
FRC #3478 (LamBot)
Jorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to behold
Thank you, this is just what I needed. I find this almost 5 years after this was released and the only thing that I can say is thank you. After an exhausting and frustrating season this is just what I needed to remind what is engineering all about. Thank you for helping me renew my passion for engineering.
Website
Facebook
Twitter
Victory goes beyond winning.
Unread 19-04-2013, 11:45
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Anyone tried replacing the pneumatic pistons with a more powerful motor and a lead screw?
Unread 19-04-2013, 14:22
Nuttyman54's Avatar
Mentor, Tactician
I would not recommend this. Due to the "crash" style of shifting rather than the dog-gear style used in AM supershifters and most FRC shifting transmissions, there's a high chance that the gears do not immediately engage. We noticed this when we built them in 2006. The pneumatic shifting style is well suited to this application, since it will apply a constant force, so it will continue to try to shift until the gears mesh right. A lead screw or other motor driven application has a much higher chance of breaking something, since you will either stall the shifting motor or continue to increase the force until something bends or breaks.
A NOTE TO EVERYONE:
This transmission was designed in 2004 for the drill motors that were given in the kits. These motors had a MUCH lower free speed rpm than CIM motors. 971 attempted to use CIMs with this transmission in 2006 and did not have good results. The transmission really is not designed to work at those loads and speeds, and required several extra stages of gearing before and after to bring the speeds down to what is reasonable for FRC drivetrains. It's a good transmission, but the design as-is is not really suitable for drivetrains with current FRC motors.
White Paper Discuss: Team 188 Woburn Robotics 2004 Gearbox Design Report CD47-Bot Extra Discussion 5 17-03-2009 18:45
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
White Paper Discuss: Chief Delphi Segway Fundraiser Info CD47-Bot Extra Discussion 1 21-06-2004 09:48
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
