Go to Post ... it's us against all the bad-grammar-usin', "ya know"-slingin', graciously excepting, "congradulations"-totin', "nu kU ler"-spoutin' linguistic Luddites out there. We'll see who wins! :D - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
View Poll Results: What do you want for 2006?
Same Kitbot 11 16.18%
Better Kitframe 19 27.94%
Better Gearboxes 19 27.94%
More Motors(same types) 29 42.65%
New Motors 27 39.71%
More Pnuematics(vari valves, etc.) 25 36.76%
More Sensors(gyro, pot, etc.) 36 52.94%
CMUCam 16 23.53%
New Sensor(Like the IR or CMUCam last year) 14 20.59%
Don't Care. We just put the brain on the tote it comes in. 8 11.76%
Multiple Choice Poll. Voters: 68. You may not vote on this poll
Unread 21-12-2005, 11:39
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: 2006 KOP Wish List
Ambidextrous control sticks would probably be the best possible addition to the kit.
Other than that, I like the idea of more pneumatics, maybe some more roller chain and a larger variety of sprockets, so we can see some variation in the teams that use the Kit bots. Also maybe 6 wheels instead of the standard 4 wheels?
Unread 21-12-2005, 12:10
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
How about some "cable chain"...
-Michael Dessingue
Unread 21-12-2005, 12:27
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Okay guys, time for a quick paradigm shift.
(With or without a clutch, up to you.)
We need to remember that everything going into the KOP costs $$$. A $5 part costs FIRST $5 x 1000ish teams = $5000. This is not trivial.
If they spend money on an item for the kit, the goal is obviously to make it an item which would be as highly utilized as possible, while remaining cost effective. They want as much bang for their buck as possible.
This is why when Paul and I were brainstorming the Kit Transmission, we came up with a highly adaptable ratio, which could be used for a variety of drivetrain speeds. We came up with a housing which could be mounted in many different ways. We came up with a method by which 2 transmissions could be combined to form a high-reduction arm gearbox. We also had to build it to be robust enough to survive life in as many conceivable applications as possible. We had to make it virtuous enough that teams would use it while still keeping the costs low enough that FIRST could afford it.
Why is it 'too heavy'?
Simple -- it needed to be robust, and was designed as such. However, it costs FIRST money to drill lightening patterns in the gears. It costs teams nothing but time to do so.
Not to pick on Conor, but if FIRST put 10 sprocket sizes in the kit, and most teams pick and use 1 size, then they've essentially wasted money on 9 sprockets per team. This is not a good thing. Instead, they must strive to include a single size that a lot of teams will use. (This is just an example).
It is all about bang for your buck.
-JV
Unread 21-12-2005, 13:06
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
FRC #0456 (Siege Robotics)
Originally Posted by JVN
...if FIRST put 10 sprocket sizes in the kit, and most teams pick and use 1 size, then they've essentially wasted money on 9 sprockets per team. This is not a good thing. Instead, they must strive to include a single size that a lot of teams will use. (This is just an example).
-JV
First off, I think the kitbot chassis and kit gearboxes are great for both rookie and veteran teams. They are both robust and flexible while keeping costs low for FIRST. If teams want to modify them like lightening the gearboxes or choping up the frame they are free to do so. I agree that FIRST can't and shouldn't put a large variety of parts (wheels, sprockets, etc.) in the kit because a lot of it will go to waste.
What about a voucher program? Let FIRST ship the KoP with the standard stuff (IFI control system, kitbot chassis and gearboxes, motors, batteries, air compressor, pneumatics hose and fittings) but NO "extra" parts (wheels, sprockets, chain, pneumatic cylinders, sensors, etc.). Then teams are given vouchers for X number of wheels, sprockets, etc. just like we do with the 3 free pneumatic cylinders from Bimba in the past. There is no waste for FIRST and teams still sort of get to pick from a limited list of standard parts but still get to design and build to their team specs. The list of standard stuff could even be known before the kickoff (like the prebuild materials list) but the big secret would be the game and what else might be on the "extras" voucher list. Let's face it. Even a lot of the stuff FIRST included in the KoP last year were not used by many teams (Skyway wheelchair wheels, CMU Cam, gear tooth sensors, latex tubing, those seat motor shafts but no seat motor, the little Mabushi motor, ...). How much did it cost FIRST for all those CMU cams last year that only a relatively few teams were able to successfully use? Would that money have been better spent another way? Maybe, maybe not, who's to say. I think it would be interesting to see what teams would come up with if they could only use wheels, sprockets, sensors, etc from a specified list but get to pick what they think they can use the best.
Unread 21-12-2005, 13:52
JVN JVN is offline
@JohnVNeun
There are a lot of good points in that post. If they implemented some sort of voucher system, then they would need to buy parts on speculation.
(i.e. "we need to buy 1000x 10 tooth sprockets, but only 50x 25 tooth sprockets because most teams like 10 toothers.")
This would be a nightmare. FIRST would either buy enough for everyone, and then have too many (loss of money), or not buy enough and cause some teams to get "shutout" of some parts.
Imagine if FIRST bought 1000 widgets at $20 a pop, but only 100 teams bought a widget. How much money are they losing?
Are there other ways to save money?
Would a veteran team say "we don't need a compressor" and give it up. What if only rookie teams received battery chargers?
Is this unfair? Everyone pays the same registration fees, can there be a rookie/veteran kit?
I hope everyone starts to realize the complications that come with the KOP.
I learned a lot about the tremendous effort involved last summer, during the Kitbot proposal and implementation process.
JV
Unread 21-12-2005, 13:54
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Originally Posted by Alan Anderson
Black CH FlightSticks.
I strongly second.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 21-12-2005, 15:40
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
I say SLASH the KOP in half, reduce the registration fees, and increase the robot spending limit accordingly.
IF we are serious about finding ways to save money associated with the KOP, why would we want to turn FIRST into a storage/warehouse/distribution/shipping company?? When ordering our "free" pneumatics in past years the "voucher"/order went directly to Bimba - that makes sense because they are already in the business of warehousing and handling their own products. Could a voucher system be set up with a certain dollar value towards certain components where the suppliers bill FIRST as the teams order the parts directly from the suppliers? There should not be any supply problems for the type of common/stock items we are talking about (sprockets, gears, bearings, wheels, etc ...)
JV
Better yet, let's save FIRST even more money - the cost of the book-keeping effort of a voucher program like this could still be significant ... Why not just shortcut the existing system? Eliminate all of the standard/stock type components from the kit, reduce the $6000 registration fee by the "value" of these items (down to $4000 or $5000), and let the teams order their own components as needed to complete their design?? We may not realize the volume discounts that FIRST is now getting, but we are also not buying "10 sprockets" for every one we use.
It seems so simple ... WE spend our money on what WE NEED. And since rookies are eligible for the $6000 NASA grant their first two years that would help them to stock up on some of the aforementioned "non-consumables" (battery chargers, air compressors, etc ...)
Other than the consideration of how much of the kit is donated, it seems to me that EVERYONE WINS in a scenario like that ... am I missing something??
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 21-12-2005, 16:58
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Correct me if I am wrong...but I believe the electronics we get with the kit (not including the speed controllers, spikes, etc.) cost around $3,000 retail. Plus, our registration fee covers one regional, shipping, etc. I don't think FIRST could reduce the fee much without cutting most of the parts in the kit.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 21-12-2005, 17:09
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Not to be a buzzkill, but where was all this discussion when we needed it back in the early summer? Anyone remember this thread and it's companions? At this point, the Kit Of Parts is locked and sealed, and there will not be any more change this year. Ideas about the KOP content, if you are serious about the suggestions, should be collected and provided as feedback after the upcoming season - after you have a chance to see what is in the 2006 KOP and have a chance to react to it appropriately. Then you can provide them via any similar threads that are started next summer or - more appropriately - at the summer team forums.
-dave
Unread 21-12-2005, 17:13
Originally Posted by Bill_Hancoc
I vote new geraboxes. Some teams cant fford to have a gearbox made or arnt capable of making their own but the ones last year were so HEAVY with 2 cims i think they tipped (or broke) the scales at 22lbs EACH!
22lbs each. Your scale is a) broken already or b) not zeroed properly or c) not zeroed at all or d) whoever weighed the gearbox didn't know what they were doing and needs training.
The mass of 1 gearbox with 2 motors is 4070 grams as measured by our students (though I suspect that they didn't zero the scale completely first, it should be close.) Translation: 4.070kg*2.5lb/kg (approximate)=10.175 lb. Your 22 lb estimate would be for a set of two gearboxes with 2 CIMs in each. Ten pounds including both motors is actually pretty good.
Unread 21-12-2005, 17:30
Billfred's Avatar
Billfred Billfred is online now
-dave
I don't think anyone with an appreciation of how long it takes to pack and ship 2,000 crates all over the world would be taking this thread seriously. (I'm not an expert, but I'll bet it takes longer than 16 days.)
In any event, I'll put the warning up: don't take this thread seriously.
Unread 21-12-2005, 17:36
Andrew Blair's Avatar
FRC #0306 (CRT)
-dave
Yeah, a little late, but I think I covered that in the intro post. This is more of a speculation, "I really hope this is what happens" type of thing to kill time waiting for the KOP, kinda like trying to guess what you got for Christmas. Hence, "chit-chat". Its more fun to speculate when you can find out about your predictions in just a few weeks. Dave, we're all sorry you can't join the fun, since you know whats in the KOP, but you're like the kid who opens his presents before Christmas! When will you learn about instant gratification...
(Dave, I'm just kidding, you know we're all extremely grateful for all the work you do for FIRST, including preparing the KOP. I will be happy with whatever is in it this year, unless it's coal or negative rep. points! )
http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=12229&directio n=DESC&sort=date&perrow=3&trows=3&quiet=Verbose
(hehe, sorry Dave)
-Sir Francis Bacon
-Albert Einstein
Unread 21-12-2005, 23:26
Stu Bloom's Avatar
-dave
Thanks Dave, I completely understand. I did not mean to suggest that any of my thoughts could be implemented for this year (I believe I saw somewhere that the kits were already packed and palletized for shipment). In fact I have no clue about the costs associated with putting the kit together (purchases, donations, packing, storage, shipping ... etc). And I won't pretend to understand any of the financial details of FIRST.
But when it was suggested that we should consider the financial impact of the additional items we were asking for in this thread it seemed to follow that the reverse was worthy of discussion. I would think that every dollar that is taken out of the kit could be transferred directly back to the teams via an equal reduction of registration fees .... NET change in overall cost to FIRST = ZERO. Savings to teams would come from the fact that we are not "paying for" 10 different size sprockets (or gears, bearings, widgets, whatever ...) while only using one or two ... or NONE. Actually FIRST could potentially realize a small savings in administrative costs from managing (procurement, storage, packing, shipping, etc...) a smaller and simpler kit.
I am frustrated that every year my team struggles financially just to be able to participate at all. I believe this program is SO good for everyone involved that it shouldn't be this difficult. Each year there are many veteran teams unable to return, and I am sure a significant number of those are due to the difficulty in sustaining the level of financial support needed to continue. I feel anything that can be done to reduce that burden should be pursued.
I know we will all be very happy with the kit contents this year, as usual. My comments are meant for future consideration in search of ways we might improve. I will definitely make sure that I bring this up at the "team forum" session I attend.
Sorry to continue this thread off-topic , so to get back on topic ...
What I would like to add to the KOP wish list is a pile of cash equal to the reduced cost to FIRST resulting from the elimination of any non-FIRST-required/specific parts.
Stuart Bloom
Mechanical Engineer
Unread 22-12-2005, 00:10
Kyle Love's Avatar
I personally want some AndyMark battery plugs...
Kyle Love
Teams I've been on:
Unread 22-12-2005, 14:56
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
-dave
Does this mean it's too late to ask for a flux capacitor?
But seriously I would be content with a kit virtually identical to last years as I was very happy with it and the work that people like JVN and Paul Cioppoli did with the transmission. I felt it was the best balance of giving the rookies what they need to get started quick and the veterans got a few things they could use to prototype really quick. All in all even though there was room for improvement in some areas I thought last year was the best kit since I've been involved with FIRST in giving everyone a fighting chance to get in the game.
Also if I've learned anything in 3 years doing this an "revolutionary" changes in the kit will make there way here quick so we are prepared. That said I would like to finally make it to a mentor debrief meeting one of these years to make a few comments. The only reason I haven't is they have conflicted with business trips 3 years running.
Pete
**FIRST EMAIL**/Wait List and Event Payment Information and Kickoff Attendance & Kit AmyPrib FIRST E-Mail Blast Archive 0 29-10-2005 22:25
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
