Originally Posted by eugenebrooks
Originally Posted by Jack Jones
<R62> The 7.2V Robot Control backup battery must be connected to the Controller as described in the
Controller’s manual (the 7.2v battery should be charged to at least 7.0v before entering a match). As a
replacement for the FIRST supplied battery, any other 7.2V NiCad battery pack may be used.
And, athough the rule clearly says that "any 7.2 volt NiCad battery may
be used" the technical inspectors refused our use of a larger 7.2 volt
battery in a prior year. If you come to a regional with a different battery
you should make sure that you also bring the FIRST provided one just
in case...
Or as all teams should, make sure you have a copy of the rule book with you during inspection (and at at all times).
