Go to Post Some clever fellow a few years back made a little scooter based on this principal and made so much on the idea he can afford the finest denim in the land. - phrontist [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 76 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 23-12-2005, 22:18
Best Available Data
FRC #1778 (Chill Out!)
Re: 2006 Official Game Hint Discussion
In keeping with the Italy theory, a Sabot is a type of wooden shoe worn in some European countries. Hmm..... Five shoes tangling with pasta?
  #62   Spotlight this post!
Andrew Blair's Avatar
FRC #0306 (CRT)
Originally Posted by sburro
Does five robots equal bigger field?
If its five total, logically it would call for a smaller field. it was 3v3 this year. 3+3=6. Yay for math!!
-Sir Francis Bacon
-Albert Einstein
  #63   Spotlight this post!
Unread 23-12-2005, 22:21
Elgin Clock's Avatar
FRC #0237 (Black Magic)
A bigger field than when there was 6? Probably not. But that's if the five 'bots refers to robots.
Everything in this clue has multiple meanings.
I'm not going to assume that "five 'bots" means five robots.
  #64   Spotlight this post!
Unread 23-12-2005, 22:28
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
well keeping with the historical joe montana perspective you could look at it like this. In 1984 Joe Montana led the NFC in passing for the second time, and won his 2nd superbowl.
In the book 1984 2+2=5 so putting everything together It will be a 2v2 set up.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
  #65   Spotlight this post!
Unread 23-12-2005, 22:33
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
But according to last year, more teams were at each reginal allowing first to due 3v3. A 2v2 would only work with less teams at eah regional OR less playing time per team, something I do not think first wants to do.
OR
smaller field and two field per regional
Sorry I ment 5v5 on the last post
K.I.S.S
Keeping It Simple Stupid
  #66   Spotlight this post!
Unread 23-12-2005, 22:35
ducttapehaxor ducttapehaxor is offline
AKA: Seth Lieblich
FRC #1712 (Dawgma)
ducttapehaxor has a spectacular aura aboutducttapehaxor has a spectacular aura about
Maybe the 'bots hint might be referring to 5 bots dots placed on the field, it would also help to fit that the bots dots are regularly in groups of 5 or 6 (this case 5)
from google searched define: bots dots
Rubberized circular bumps that are aligned in groups of five or six to represent dashed road lines. Bots Dots replace painted road lines in sub-tropical or tropical climates. They are not used in colder climates as they would be ripped off by the snow plows.
Try to look unimportant; the enemy may be low on ammo.
The only time you have too much fuel is when you're on fire.
  #67   Spotlight this post!
Unread 23-12-2005, 22:36
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
My guess is 3v3 like last year but there will be some sort of task at the beginning that there will be some sort of race to do first. The first alliance to get this task done gets to disable one of the opposing alliances robots thus making 5 active robots on the field. Autonomous will again be at the beginning thus making it more important to disable an opposing robot.
I vote pasta = pool noodles as scoring objects.
  #68   Spotlight this post!
Unread 23-12-2005, 22:49
http://www.tedsmontanagrill.com/
I like that Montana reference a lot better. And guess what? It's owned by Ted Turner, founder of among other things, Turner Entertainment, based out of Atlanta, GA.
That quite possibly has to be more than a coincidence, and if it's not that's just amazing.
Also, dealing with the Montana FIRST connection; of the 10 teams form Montana, none are registered for The Championship event, but 9 out of 10 are definitely sponsored by NASA.
  #69   Spotlight this post!
Unread 23-12-2005, 22:58
iR3 Creative
AKA: Dan Richardson
Originally Posted by Elgin Clock
so what are you saying, elgin, is we are going to be using inflatable BUFFALO!!!!??? WOot
  #70   Spotlight this post!
Unread 23-12-2005, 22:59
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
No, inflatable clowns!
  #71   Spotlight this post!
Unread 23-12-2005, 23:13
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Re: Official FIRST Hint declassification
Is this serious, I would of thunk that they release Dec 30
  #72   Spotlight this post!
Nathan Pell's Avatar
Nathan Pell Nathan Pell is offline
FRC #0233 (The Pink Alliance)
Nathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to behold
I did some googling on the shovel issues; I thought this was interesting since last year's hint had a musical reference to it.
"Pank Shovel's music is as unique as its members. Their sound is a Punk Rock/Hip-Hop hybrid that crosses boundaries and challenges the genre's traditional misogynistic stereotypes. Their songs strong lyrical content describes real life experiences with childlike imagination."
So could the "Shovel's show" mean Pank Shovel and one his songs?
Florida First
  #73   Spotlight this post!
Unread 23-12-2005, 23:17
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Sorry didnt have time to go through all the posts this might be a repeat. The last two lines look like they belong together making this a riddle(obviously).
five 'bots tangling with pasta
a game piece obsessed with a shovel's show and seeing Montana's green heights
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
  #74   Spotlight this post!
Unread 23-12-2005, 23:23
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
In reading some info on the state Montana, here was an excerpt:
"...and the dry farming was very successful with the comparatively new and valuable crops of durum, or macaroni wheat, and Russian barley, which is used in straw for winter feed to sheep and neat cattle."
Macaroni = pasta... Maybe instead of corn on the field, it's wheat, or hay, or possible a mess of pvc batons (like said many times). Heh, who wouldn't love to have wheat all gnurled up in their drivetrain.
I don't think they will be pool noodles. Those tear apart very easily, can you imagine robot claws digging into those things?
Also, Montana's green heights. Joe Montana and Trent Green both quarterbacks, yeah? Both had some great successes and "heights".
Montana, as stated has a lot of varied terrains and physical elevations. I definitely think there will be a vertical aspect to this game, but, in what way who knows.
Minerals and Mining have been the lead industry in Montana since the 1800's. Lumber, forests, logging shovels... a game piece obsessed with the shovel's show... maybe...some animal in the forest who doesn't want the logger to tear down the lumber... lol.. I don't know where to go with that yet.
Just a few incoherent thoughts as of now.
And yes Freddy204, this hint came directly from the FIRST personnel.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
  #75   Spotlight this post!
Unread 23-12-2005, 23:29
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Originally Posted by Andrew Blair
Secondly, the 5 robots tangling is probably not to be taken literally, but consider this for the strategy people: What if the format was 3 vs 3, and 1 robot from either alliance had to voluntarily agree to sacrifice their driving ability (i.e., stay on a pressure pad), in order for either alliance to play. So, for example, for 15 seconds into the gameplay after autonomous, if noone had gotten onto the pressure pad, noone would play till like the last 25 seconds, or not at all. If nothing could be worked out between opposing alliances, the best autonomous would win the day. Man, I hope thats not it though. Bit too evil for my liking...
That would be great!!!
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
2006 game poll #1 (field size) dhitchco Rumor Mill 18 30-12-2005 23:31
2006 game poll #2 dhitchco Rumor Mill 1 23-12-2005 22:57
[Official 2006 Game Design] Autonomy And Other Technology Discussions dlavery FRC Game Design 36 12-11-2005 17:49
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
