Go to Post I don't even care if it doesn't work as well as they would like. YOU MADE IT. You may never use it, but you made it. AWESOME. Every year there has been 1 team (sometimes 2) that has done something that really stood out. This year 1 team has done 2 things that stand out. Thanks guys. - rees2001 [more]
Unread 25-12-2005, 23:50
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Linkage bars
does anyone kno where to get the linkage bars like the ones in the attached picture?
Unread 25-12-2005, 23:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Linkage bars
I assume you are talking about the ones with black ends. Those would be RC car rod ends and turnbuckles. Your local hobby shop that stocks RC products is the best bet. If you want to order online, search www.towerhobbies.com for "rod end" and for "turnbuckle". There are also some nice ones here http://rc4wd.com/shop/index.php?cPat...8385 d820a819
You can also check www.mcmaster.com for "rod end" if you need bigger ones.
Let me know if you have any more questions.
Unread 26-12-2005, 00:25
occra 23.
AKA: ryo
None #1481
Re: Linkage bars
definitly hobbyshop. and i dunno how much tensionis going into them but fairly strong paperclips work for emergencies.. and well. the thicker heavy duty paper clips i guess they are called. the ones with a black clip and two "foldable" "handles" on them... those handles are quite strong. a needlenose and a vise will be all you need.
Unread 26-12-2005, 09:44
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Linkage bars
I knew they used them for the steering linkages on TMAXX and all those cars but I didnt know if I should use the same ones or if there was a different kind for non-rc things.
Klondike bars sciguy125 Chit-Chat 10 26-10-2005 16:35
Help Upgrade CD Steve W General Forum 60 07-04-2005 22:44
pic: Team 190 WPI blocking the bars! CD47-Bot Extra Discussion 13 26-05-2004 19:31
Best Wheel Grip? archiver 2001 20 23-06-2002 22:38
Thickness of aluminium bars Randy_Ai Technical Discussion 1 04-02-2002 20:09
