Go to Post But now we know what's inside Shaun's backpack! ...Don Rotolo's plastic egg. - MishraArtificer [more]
Unread 27-12-2005, 13:36
complete's Avatar
complete complete is offline
complete is an unknown quantity at this point
reading negative numbers from a file in VB
So far the code I have written can read and write to and from a file.
In other words, I have the
    Line Input  #FileNum...
and the
     Write #FileNum...
written.
But how do I handel a situation where the file has negative numbers to be read? I am able to output to a file a negative integer. But when I try to read it back I get an error.
I assume I will have to read each line of the file one by one into a string and then have it converted. What are the string conversion routines in VB? The line of code is written as
-1
I suppose I have to do some string manipulation to get it stored back as a negative integer.
Unread 27-12-2005, 14:18
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: reading negative numbers from a file in VB
http://www.chiefdelphi.com/forums/sh...ad.php?t=29944
Replace Delphi with your programming language of choice (minus PIC C)
This is not a general programming website. We are for the FIRST robotics competition.
http://www.mikesorrenti.com/
Unread 27-12-2005, 16:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Although we can try to help.
I don't know VB worth crap, so there could be an easier way, but I'd say that you could check if it begins with a '-,' strip it off if it does, convert the main part to a number, then multiply by -1.
IE, if you have "-5" in a file, you take off hte negative ("5"), convert it to a number (5), then multiply by -1 (-5).
Unread 27-12-2005, 17:28
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you're using the Write # statement, you should use Input #, not Line Input #.
Otherwise, VB is very good about preserving data.
Unread 27-12-2005, 19:24
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
I believe the string conversion routine you're looking for is:
val()
It'll convert a string to a number.
The opposite is:
str()
(which converts a number to a string).
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Error in header file p18f8520.h !!! RbtGal1351 Programming 3 17-01-2005 16:03
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
