Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 29-12-2005, 21:48
Umm Errr...
A look inside a victor
Ever wanted to know what a victor looks like inside but were to afraid to void your warranty? Thats ok, I voided mine for you.
Here you can see the victor that will be the subject of our disassembly
With the fan removed
The back showing voided warranty
Oh no! the circuit board is glued in!
vBulletin is complianing i have too many images in this post so it will be continued in the next
1139 Alumni
Unread 29-12-2005, 21:49
Umm Errr...
Re: A look inside a victor
A careful hand and an X-acto around the glue freed the board. Note how the silkscreening says this is a victor 883 while it is actually an 884. Also note the plant-like matter in the conformal coating around the LED in the bottom right.
Here is the underside of the board. It is also conformal coated
Here is a pile of parts
1139 Alumni
Unread 29-12-2005, 22:35
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Not much surprise there. Now, it's time to make a schematic and build one yourself out of RadioShack parts!!!
JBot
Aren't signatures a bit outdated?
Unread 29-12-2005, 22:40
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
nicely done
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 29-12-2005, 22:46
Andrew Blair's Avatar
FRC #0306 (CRT)
Ahaha! I see your's still contains all it's magic smoke, eh? I'm not all that surprised at the 883 silkscreening though: the 883's run exactly the same way as the 884's. As far as I can tell. Maybe they just kept the boards and upgraded the components?
-Sir Francis Bacon
-Albert Einstein
Unread 29-12-2005, 23:03
Umm Errr...
JBot
Even if you build one from identical parts, you will still need the code that resides on the PIC. PICS are very secure even to the most sophisticated attempts to steal their code.
1139 Alumni
Unread 29-12-2005, 23:06
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I thought that this was probably not possible
Unread 29-12-2005, 23:09
Umm Errr...
Unfortunately not
If you google something like "12v speed controller" you can find plenty of DIY designs.
1139 Alumni
Unread 29-12-2005, 23:12
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
How about ripping the PIC off of a white-smoked Victor? The thing's pointless anyway, and I doubt the chip would die before the current-bearing stuff. Just something to do in that time between regionals...
Unread 29-12-2005, 23:18
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Huh? Only if code protect is enabled. Otherwise you could just read the code striaght off it with an ICSP cable, and dis-assemble it.
Not that its that complicated anyways. I don't see the reason to put any effort into copying IFI's product when there is stuff like OSMC already done (open source motor controller, google it).
Unread 29-12-2005, 23:23
Umm Errr...
I know from trying that code protect is enabled on all the PICs in IFI products with the exception of the user processor in the RC. There is no (publicly) known way to get around the code protection. I agree with you. There are simpler open designs if you want to build your own.
1139 Alumni
Victor and Spike in same circuit? phillutz Electrical 4 18-02-2005 16:57
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Victor 884 Calibration Incorrect Just3D Electrical 4 15-02-2004 15:20
Victor Size Problem Jeff Waegelin Inventor 3 24-02-2003 15:35
