Go to Post Their robot moves so fast that it changes colour due to the Dopler Effect. By rapidly alternating between driving away from the viewer (Redshift) and driving toward the viewer (Blueshift), they can make the viewer see it in their traditional purple colour. - philso [more]
Unread 30-12-2005, 21:26
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: FREE CoreChartFR
Originally Posted by Eldarion
But this software is kind of like Mindstorms for the FRC, so how does that require more skill?
Because core chart is a graphical assembler, not a graphical high-level language program. There are no floats - there arn't even any 16-bit variables. Everything is 8 bits, period. You are 100% limited to the PIC 18 instruction set. Want to store a literal (like 0x77) in a variable? You can't just move it right into it, you have to move it into the working register and then into the variable. There are not blocks for everything you want to do like there is in mindstorms, you have to create everything out of assembly instructions.
Take a look at the .lst that c18 makes for you. Every assembly instruction there would be a block in corechart.
I'm not saying I would use it - I'd program in C, and if I had to use assembly I'd do it by hand. I am, however, saying that it requires more skill than writing C code in MPLAB. All it does for you is makes it so you cant screw up the syntax.
Free Service At 2005 Florida Regional mdion Regional Competitions 5 04-03-2005 11:46
Free Service Available For Teams At Nationals 12th-martyr Technical Discussion 5 03-05-2004 00:21
