Go to Post I am definitely as much a student as any one of the kids on the team. - Hieb [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 76 votes, 5.00 average. Display Modes
  #466   Spotlight this post!
Unread 31-12-2005, 14:11
funstuff's Avatar
funstuff funstuff is offline
AKA: Kat
FRC #4096 (Ctrl-Z)
funstuff has a spectacular aura aboutfunstuff has a spectacular aura about
Send a message via AIM to funstuff
Re: 2006 Official Game Hint Discussion
We mentioned before a pentagonal ramp. Well I just woke up in the middle of the night and thought of this... if there is a pentagon shaped ramp, the field would not be entirely symetric. that may or may not matter but the fields usually had strong symetry to them. both on the red or blue side, and on the left and right. i was also considering the size of a robust pentagon ramp and what kind of effect it may have on cramping the field. it could be done, but im not sure. After all the 2003 ramp took up a large portion of the feild then and that was only 2 sides! think of how large a 5 sided ramp would be? yes the field is larger, but is it THAT much larger? i dunno... anyone elses thoughts?
Good point. But if the ramp has FOUR sides and ONE flat top (like a plateau), doesn't that mean that there is room for FIVE robots? This would work better with the symmetry of the field. The top spot would of course be worth the most points. The ramp would take up a lot of room on the field, no matter what it's shape is. Think like these trucated pyramids, except less steep:
2011-present | FRC 4096 | Technical/Mechanical Mentor
2006-2007 | FRC 624 | Electrical Subteam Captain, Strategist
2005-2006 | FRC 624 | Build Captain, Driver
2004-2005 | FRC 624 | Mechanical Subteam Captain, Driver
2003-2004 | FRC 624 | Driver
  #467   Spotlight this post!
Unread 31-12-2005, 14:19
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
that makes a lot of sense...i'm assuming that it wouldn't be mobile, b/c that'd be REALLY hard to climb on if it was... and dangerous too.
  #468   Spotlight this post!
Unread 31-12-2005, 14:43
Best Available Data
FRC #1778 (Chill Out!)
Actually, that brings up a really good point. Assume that while "five 'bots are tangling with pasta" there is a truncated pyramid or similarly shaped object on wheels like the mobile goals of '04, or the puck of '98? (in that year robots physically got on top of the puck and were awarded points for it). There would be points for the robot atop of the rolling truncated pyramid (isn't that just a fun word to say?) at the end of the match. Probably in order for most bots to climb it they would need help of an alliance partner, but good robots could mount it themselves leaving 2 of their robots to tangle with pasta while they fended for themselves.
And could you imagine getting on said object in Autonomous Mode?!?!?!?
  #469   Spotlight this post!
Unread 31-12-2005, 14:57
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
[I only had time to read about half of the thread... so don't kill me if I'm repeating here...]
A few things discovered in 15 minutes worth of research, none of which I've seen here yet:
1) Couldn't help but Google the exact phrase "five 'bots"... and lookey here what it discovered: http://www.fileaholic.com/idgames/pa...d/coderd12.txt
Knowing the geekiness of the GDC (thats "geek" in the good sense)... I'm guessing there might have been a Quake player or two out there... Notice that "You begin in a level with entrances to three(for now) arenas". *3* !!!
2) Now to dictionary.com... "Tangle: To catch and hold in or as if in a net; entrap".... speaks for itself.
3) PASTA is an acronym in queuing theory; it stands for "Poisson Arrivals See Time Averages". A wildshot... but then again, could have something to do with the scoring system.
4) There is a meaning of "show" that I haven't seen mentioned... again thanks to dictionary.com... "Show: Third place at the finish, as in a horserace." I dunno.... there's that "3" again. Also, "obsessed" can mean "influenced or controlled" SO: Translate: "A game piece influenced or controlled with a shovel's third place finish." Yike's -- the value of a gamepiece might be different for the third place finisher?
I won't touch Montana's green heights for now.
Happy New Year!
Aidan
  #470   Spotlight this post!
Unread 31-12-2005, 15:08
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I just thought of this, instead of having the ramps/platform in the middle, they may be at the ends of the field like a end zone in football. This just came to me when I was reading about Montana's heights/Joe Montana. I think it would be cool if they placed the ramps and goals at the ends like end zones, and have the robots start in the middle... Just a crazy idea.
  #471   Spotlight this post!
Nuttyman54's Avatar
Mentor, Tactician
Happy New Year!
Aidan
that might've been mentioned before, but never connected like that....if we had a third place, that would imply three alliances...maybe that's how FIRST is combatting the "ganging up" problem that occurred last time there were three teams playing at ta time...
  #472   Spotlight this post!
Unread 31-12-2005, 15:09
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Similar to 1995's game:
http://www.firstwiki.org/Ramp_n%27_Roll
  #473   Spotlight this post!
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
the field will be cheap.. prob as cheap as last year..and as easy to create.. so I wouldn't count on a 10ft hill
also if it's 5 bots... it won't be 2v3 -- that would take way TOO much planning and could be a catastrophe
5v0 is very possible -- alliances could have the opportunity to end a match early again - and if the avg time of a match is 1:40 or so.. it would make up for not having a 6th team on the field
  #474   Spotlight this post!
Unread 31-12-2005, 15:19
Gundamx92000's Avatar
Gundamx92000 Gundamx92000 is offline
AKA: Ross
FRC #0166 (Chop Shop)
Gundamx92000 is on a distinguished road
Send a message via AIM to Gundamx92000 Send a message via Yahoo to Gundamx92000
What if it was a standard ramp like in 2003 with rope netting instead of wire grate? and then the top of the ramp could only hold five? remember how the ramp only fit so many in '03? its a little flooky, but maybe...
Ross Martin
Team 166
CHOP SHOP
"No Ross, I am not going to wear a kayak..."
"Yeah... but then we'd have to clean the shards out of the lawn..."
  #475   Spotlight this post!
Unread 31-12-2005, 15:41
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
Another really crazy idea, but what if the truncated pyramids are at the end zones like Norris said. You begin on top of the pyramids and at the end autonomous period, you have to use the CMUcam to find your way back on top of the pyramid
  #476   Spotlight this post!
Unread 31-12-2005, 15:47
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
The ramp/platform in 2003 could hold 4 robots, the number that played the game that year. It happened many times during Regionals and Championships.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
  #477   Spotlight this post!
Unread 31-12-2005, 16:05
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Oh my god, this is a good find. This makes me think that it will be a 2x2 game with a FIRST-controlled defensive bot defending the top (where there will be a goal for the footballs).
Ramps will have to be scaled by robots during the end of the match--which will be autonomous--for extra points...and they must have started *off* the ramp before autonomous began.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
  #478   Spotlight this post!
Unread 31-12-2005, 17:11
tfedullo tfedullo is offline
Captain
FRC #0375 (Robotic Plague)
tfedullo is an unknown quantity at this point
i don't know about an autonomous task at the end of the match, it would make the ref's job hard to make sure the task was not completed (or started) during operator controlled mode
though, it would be an interesting twist
2006 New York City Regional Chairmans' Award Winner
2006 New York City Regional Winner with 395 and 1880 Winner
2006 New York City Regional Autodesk Visualization Award Winner
2006 New York City Regional Radioshack Innovation in Control Winner
2006 Trenton Regional Finalist (thanks 486 & 1860)
2006 Trenton #2 seed
2005 Trenton Regional Winner (thanks 1279 & 103)
2005 New York Regional Winner (thanks 395 & 1230)
2005 New York Motorola Quality Award Winner
2004 New York Johnson and Johnson Sportsmanship Award Winner
2003 New York Imagery Award Winner
  #479   Spotlight this post!
Unread 31-12-2005, 17:37
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
--Petey
How would you introduce a house robot?
This would tick people off more than anything FIRST has ever done in the past. Unless it just sits there, or drives around with flashing lights all over it, far away from the action, there's no way to keep the robot from adversely or positively effecting the rest of the teams. Everyone would complain that xx alliance got more help from the house bot than yy alliance, and zz alliance got completely screwed, etc.
Plus, how on earth are teams supposed to build their own robot, PLUS a second robot, just to have a working field?
This isn't battlebots, where the entire goal is to destroy everything else on the field. There's no way there's a house bot.
2001-2004: Team 100
2006-Present: Team 254
  #480   Spotlight this post!
Unread 31-12-2005, 18:06
Sam Lipscomb's Avatar
Sam Lipscomb Sam Lipscomb is offline
CTFIRST Volunteer Coordinator
AKA: sambang
FRC #3780 (Robot Unicorn Attack)
Sam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond reputeSam Lipscomb has a reputation beyond repute
Send a message via AIM to Sam Lipscomb
That's true. There's no way there would be any housebots that do specific tasks, like defend, otherwise teams would need to build their own housebot in order to practice before competitions. Most teams only build pieces of the field, so it's doubtful FIRST would make us build another robot too.
gaelhawks230 alumni
unicorns3780 mentor
slipscomb@ctfirst.org
@sambang
bc2010
CTFIRST VC
queuing
#15!
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
2006 game poll #1 (field size) dhitchco Rumor Mill 18 30-12-2005 23:31
2006 game poll #2 dhitchco Rumor Mill 1 23-12-2005 22:57
[Official 2006 Game Design] Autonomy And Other Technology Discussions dlavery FRC Game Design 36 12-11-2005 17:49
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
