Go to Post I've now read Dolly Parton's entire wikipedia page, which was not something I expected to do - WinterPoet [more]
Unread 31-12-2005, 00:42
Umm Errr...
A tour inside the RC
I posted this already, but the host went down and the forum software wouldn't let me edit the URLS so i am posting it again. I will try to get a mod to delete the old thread
click any of the pics for a high res version
I did some warranty vioding on the RC. Here are the results:
Here you can see the Hidden ISCP headers for the master and user processor as well as some pins labled TX and RX. I presume this is a tap to the data to the radio modem or a serial port on the master proc. Also visible is an unsoldered mystery header. I will trace these as well as the TX and RX pins when i have time. You can also see that ther is space for 3 more LEDs. That thing in the top middle is the user processor. Those two dimpled chips on the left are buffers which allow the mater processor to disable the user processor from controlling the relay outputs.
Here you can see the back of the board. Nothing too interesting here. More or less one big groundplane.
Here is an overview of the whole thing. At the right of the pic is the power supply circuirty which consists of three regulators, some diodes so that it doesn't explode when hooked up backwards, and some auto resetting fuses. The top regulator provides power 5v power to all the external pins such as the digital and analog IO ports. The middle regulator provides power to the internal curcuits of the RC itself. The circuitry which switches from main to backup power is at the top right around the orange fuse. The bottom regulator powers the OI when it is connected to the RC through tether. Intermingled with the power supply circuitry are the rs232 and rs485 converters for the program port, tether and the radio modem. In the middle of the image you can see the master processor and the user processor. They are the big square chips. The one on top is the master. It looks like they share a single crystal oscillator as a clock source(the little metal thing to the top right of the master processor.
1139 Alumni
Unread 31-12-2005, 10:44
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: A tour inside the RC
Hey Rickertsen2, thanks for all of the great pictures lately, I've always wanted a peek inside of the RC but my team would kill me if I opened it up.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 31-12-2005, 13:30
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
If you have the right kinda of paper for you printer you can print new stickers.
Unread 31-12-2005, 13:46
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Except you would most likely be asked by an inspector to remove the stickers to show you're using the standard RC.
Unread 31-12-2005, 13:59
Best Available Data
FRC #1778 (Chill Out!)
And why bother to use an old RC when a purty new one will be arriving in the mail shortly?
Unread 31-12-2005, 15:14
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
nicely done once again I always wondered what was in there...
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 02-01-2006, 19:55
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Do you still have access to the guts of that RC? Could you see what processor pins the Master and User headers go to? I am curious what their function is.
Here is a link to the datasheet for the processors if anyone is interested:
http://robotics.dyndns.org/PIC18F8520.pdf
Thanks for posting the pictures!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 02-01-2006, 20:01
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
My best guess would be ICSP, which would be RB5, VCC, GND, RB7, and RB6. Not necessarially in that order.
Unread 02-01-2006, 20:04
Eldarion's Avatar
Pardon my ignorance, but what does ICSP stand for?
-- Thomas Paine
-- Anonymous
Unread 02-01-2006, 20:57
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
In Circuit Serial Programming, iirc.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 02-01-2006, 21:19
Eldarion's Avatar
Thanks, Google confirms this. (If you just type in ISCP, a whole bunch of unrelated stuff comes up).
-- Thomas Paine
-- Anonymous
Unread 04-01-2006, 20:30
Umm Errr...
They are ISCP. They use the standard pinout. I traced them already. For those of you who do not know what ICSP is it stands for In Circuit Serial Programming. It allows you to hook up a PIC programmer and upload code to a PIC while it is in a circuit. There is one for the master processor and one for the user processor.
I figured out what the RX and TX pins were, but i don't remember. I think it is a tap on the link btw the master and user. My question is what the blank space that looks like there should be a connector is for. I seem to remmeber the pins going to some GPIO on the master processor.
I still have the thing disassembled in a drawer if anybody wants me to elaborate on anything.
1139 Alumni
Unread 04-01-2006, 20:51
Eldarion's Avatar
Could you tell me what the pinout on the Competition port is? I have heard rumors that IFI uses a serial interface; just curious if there were pins going to a UART or something.
You could try booting it up with an oscilloscope on each of those pins and see if they are even active or not. Maybe they're just for future expansion, and the software doesn't even use them right now.
-- Thomas Paine
-- Anonymous
Last edited by Eldarion : 04-01-2006 at 21:05. Reason: COMPETITION port, not arena port!
Unread 05-01-2006, 10:22
RoboGeek RoboGeek is offline
AKA: Matt Kinnison
#0063 (The Red Barons)
RoboGeek is an unknown quantity at this point
Send a message via Yahoo to RoboGeek
just curious while you have it apart can you tell me which pins in the competition port are the power inputs? I know they are there somewhere but the team would kill me if I removed those d@mn stickers!!! thanks in advance for any help
Unread 10-01-2006, 15:23
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
Need help with RC "initializing".
The Program State LED on the RC is solid yellow and can't get it reset
The RC Mode LED is solid yellow
The Code Error LED on the OI is solid red
Nothing seems to be working. Can't download program to RC. I did notice that the "User code" in the display window of the OI reads "012".
Any help is appreciated.
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
A look inside a victor Rickertsen2 Electrical 10 29-12-2005 23:23
Tour De Georgia Peter Matteson Championship Event 3 08-03-2005 20:21
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
loops inside of subs??? manodrum Programming 4 19-02-2003 20:05
