Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
Unread 02-01-2006, 13:15
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
New Rules for the 2006 AVA
Have you all seen the rules? Your team contact should have received an email from FIRST.
Notable changes this year:
  • New deadline: Paperwork by Feb. 6, animation and storyboard by Feb. 13
  • Must be in QuickTime format. No DiVX, Cinepak or any other codecs.
  • You have 2 chances of going to final judging: winning a regional AVA or being selected by the Autodesk judges
  • 3 National Awards: Championship, Honorable Mention (new) and Rising Star (Rookie)
  • New theme: "Ideas Realized – the process of visualizing what you want to achieve from being part of FIRST."
Unread 02-01-2006, 13:40
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: New Rules for the 2006 AVA
  • Must be in QuickTime format. No DV, DiVX, Cinepak or any other codecs.
Just a clarification on the video compression: the file format must be QuickTime (.mov), and the codec used must be DV-NTSC.
There is also a plethora of strict new regulations about frame rate, resolution, placement of text, audio levels, etc. so make sure you read the rules posted on Streamline before you start animating.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 02-01-2006, 16:43
mehul mehul is offline
no team (Technotics)
Team Role: Animator
mehul is an unknown quantity at this point
"the codec used must be DV-NTSC"
so i guess this would mean there is no size limit on the animation unlike last year where it was set to about under 300mbs if i remember correctly. If we use that compression i think it would give out a larger size than other compressions like divx or the cinepac mention before. I havent read all the rules yet it would be nice if someone posts it here
Unread 02-01-2006, 16:50
AKA: Kevin Thorp
Size limit is 250 Mb.
I'd post the rules but they include login information to Autodesk's Streamline site, and I dont know if they want that in a public forum.
Unread 02-01-2006, 16:53
Circuit Breaker
The rules can be found in the attached doc.
File Type: doc Autodesk Visualization Award 2006 FINAL.doc (78.5 KB, 119 views)
Patrick Fairbank
patfairbank.com
Unread 02-01-2006, 16:58
Best Available Data
FRC #1778 (Chill Out!)
I <3 the animation guys who changed what animators must animate. Now the only problem is tracking them down and awarding them with a cookie as I promised earlier in another thread, which I can't seem to find. Ah well, now we need to complete the animation this year.
That deadline really scares me.
Unread 02-01-2006, 17:03
Team Role: Animator
hmm i read the file and as i though before there is no size limit to next years competition unless first posts it la8er. The codec we are used last year allowed us to compress our animation from about 1 gig to about 150 mbs -cinepac so dv would be larger file . anyway thanks for the info
-team1635 animator
Unread 02-01-2006, 17:05
Team Role: Animator
well that info is already in the usfirst website so its already public.
Unread 02-01-2006, 17:17
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
not exactly...only those who have streamline can access it.
Unread 03-01-2006, 18:36
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Whew, for a minute i thought they changed the content requirements. Theme changed, but that's easy to work with. This is my first year leading the animation team, so none of the format changes affect me. Before this my superiors did all that.
BTW, since windows movie maker doesn't support quicktime i don't think, is there a free video program so i can add the slate and black parts, as well as the voiceover?
Unread 03-01-2006, 18:41
Nuttyman54's Avatar
Mentor, Tactician
AVID Free DV should be able to do that
Unread 04-01-2006, 08:17
AKA: Kevin Thorp
Our video editing software doesn't do Quicktime either. I started a new thread about video editing:
http://www.chiefdelphi.com/forums/sh...613#post426613
Unread 05-01-2006, 19:31
BruceJ BruceJ is offline
BruceJ will become famous soon enough
Just a quick tip for those who haven't used "safe frames" before.
In 3ds max, the settings you use in the Render Scene dialog will determine the aspect ratio of the frame when it is rendered.
The viewport can show this as a box known as the "live area" by right clicking on the viewport name and selecting "show safe frame".
By default, the live area is the largest box, then action safe frame/box at 10%, then the smallest is title safe at 20% from the edge of the live area.
This year's award guidelines say everything should be within a 15% boundary from the edge of the live area (which you should set to NTSC DV or 720x480 in the Render Scene dialog).
So you could go to the Customize menu, Viewport configuration, and select only Title Safe for example and set it to be 15.
If so, then in your viewport you will see the live area and another box inside of it at 15% from the edge.
-Bruce
Animation mentor, team 111
Unread 05-01-2006, 19:39
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Back when I started out in 2002 we had amost nine weeks to do the animation. Now it's down to five.
Autodesk is killing me!
Unread 06-01-2006, 02:09
Li Jianliang Li Jianliang is offline
Li Jianliang has a spectacular aura aboutLi Jianliang has a spectacular aura about
Paperwork will be a cinch but only five weeks to animate... Last year, my team spent at least a week or two just brainstorming ideas for the animation. Looks like we really have to step it up this year. (Ahh, the sleepless nights await!)
I wonder why AutoDesk implemented the new method of getting to the National round...
What I want to achieve from being a part of FIRST: Dine on fine American food with teammates and playing around hotel lobbies at the Regionals.
Seriously.
FIRST FANTASY RULES DISCUSSION 2006 Levin571 Fantasy FIRST 17 12-03-2006 14:21
On Rules, Referees, and Rewards (aka Penalties) RyanMcE General Forum 29 21-03-2005 13:20
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
Time for new rules! archiver 2001 11 24-06-2002 02:01
