Go to Post There are NO old, bold electrical engineers! - Al Skierkiewicz [more]
Unread 02-01-2006, 06:34
winners winners is offline
winners is an unknown quantity at this point
Ultrasonic Sensor
Dear sir/madam,
Where can I find, please, some open sample codes for programming the vex ultrasonic sensor as for easyC?
I'd appreciate any help given.
Thanks in advance!
Unread 02-01-2006, 11:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Ultrasonic Sensor
Originally Posted by winners
Dear sir/madam,
Thanks in advance!
Welcome to Chief Delphi Forums!
The test code for all of the Vex sensors (including the ultrasonic sensor) for EasyC is located by default in the following directory when EasyC is installed.
C:\Program Files\Intelitek\easyC\Projects\Test Code
Inside this folder should be a file named ULTRASONICTEST.ECP. This file contains the sample code used to run the Ultrasonic sensor. Here is basically what is contained in that file:
#include "UserAPI.h"
int ultrasonic;
void main ( void )
      //Connect Input Wire to Digital Output 11
      //Connect Output wire to Interrupt 1
      //Near = 2, Far = 100
      StartUltrasonic ( 1 , 11 ) ; // interrupt 1= output label on sensor, DO11=input label on sensor
      while ( 1 )
            ultrasonic = GetUltrasonic ( 1 , 11 ) ;
            PrintToScreen ( "ultrasonic =%d\n" , (int)ultrasonic ) ;
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-01-2006, 15:31
Even though I already found the sample, Thanks for your support!
Unread 02-01-2006, 20:55
KINGOFCLUBS454's Avatar
KINGOFCLUBS454 KINGOFCLUBS454 is offline
Creamer Connoisseur
AKA: Andrew
FRC #0357 (Royal Assault) VRC #KTOR (Knights of the Olde Robotics)
KINGOFCLUBS454 has a spectacular aura aboutKINGOFCLUBS454 has a spectacular aura aboutKINGOFCLUBS454 has a spectacular aura about
Send a message via AIM to KINGOFCLUBS454
Hmmm...If you gave an idea of what you are looking fro it to do I could whip you up a quick sample of it...If none of the other guys on here beat me to it
PATENTed
VRCC KTOR - Captain
FRC357 - Alumni
FRC2023, FTC508 - Mentor
FLL5297 -Mentor
Using and Coding an ultrasonic sensor Jaine Perotti General Forum 14 06-08-2004 14:13
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
