Go to Post WE might have a different plan than being overweight, but thats just my guess - pakrat [more]
Unread 23-12-2005, 00:02
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
White Paper Discuss: Handy script to examine the size of your code
Thread created automatically to discuss a document in the White Papers.
Handy script to examine the size of your code by kc8nod
Unread 23-12-2005, 00:05
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Re: White Paper Discuss: Handy script to examine the size of your code
Hi, I'm having a few problems with this script.
When I tried using the script the first two lines were as follows.
Unused Memory             28651 bytes 93.3%
vfprintf()                 3062 bytes 10.0%  vfprintf.c
Is this a bug in the script, or is it something I'm doing?
I have a feeling that my code is actually larger than the maximum possible size and somehow this is affecting the result.
Thanks.
Unread 25-12-2005, 23:19
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
Quite possibly. The size of the flash is hard coded in the script as 0x7FFF. If your code exceeds that size bad things might happen. If you could post or email your .map file I could probably figure out what's going on.
Unread 27-12-2005, 19:52
prograid's Avatar
AKA: Ben Cherian
Thanks for replying.
By the way, I don't think this should make a difference but the script is being run as a post-build command from within eclipse.
The mapfile is in the attachment in the FRCMapfile.zip archive because the forum does not allow text file attachments of greater than 100kb.
Thanks.
Unread 03-01-2006, 11:03
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
...the script is being run as a post-build command from within eclipse.
Sorry for the slow response, I've been offline last week.
I'm guessing that you are doing something clever with your linker script and that is confusing the codsize script. Are you even using the linker script? I can only imagine what hacks you have had to perpetrate to make mcc18 work under Eclipse. Anyway, from your mapfile:
                              Program Memory Usage
                               Start         End
                            0x000800    0x000814
                            0x000818    0x0063a0
                            0x300000    0x30000d
            23468 out of 33816 program addresses used, program memory utilization is 69%
My codesize script is improperly concluding that your program ends at address 0x000814 rather than 0x0063a0. My unfounded guess is that you have an extra CODEPAGE entry in your .lkr file.
At any rate, the bug is indeed in my script. I'll think about this a bit more and post a fix in a day or two.
Unread 03-01-2006, 11:20
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
BTW, here's the proper output from the .map file you posted.
Unread 06-01-2006, 19:50
prograid's Avatar
AKA: Ben Cherian
Does your script use the linker script (I'm assuming you mean the 18f8520user.lkr file.) in calculating the usage of code? B/c in eclispe the linker script is a directory level up from the mapfile, but in the same level as your perl script.
This is the command I run in order to run your script:
perl "..\codesize.pl" "FRCMapfile.map"
Thanks, for your help.
EDIT:
I tried running your script from within the plain old windows command line after copying the mapfile into the same directory as your script and the .lkr file (and run this command: perl codesize.pl FRCMapfile.map), but still get the same output. I'm using ActivePerl 5.87 Build 815 on Windows XP just for your info.
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
White Paper Discuss: FIRST Sponsorship = Excellent Corporate Strategy Chris Fultz Extra Discussion 0 12-04-2005 20:23
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
White Paper Discuss: Continuous Improvement Process for FIRST Teams Chris Fultz Team Organization 2 05-01-2005 20:52
White Paper Discuss: CopyCat Code v1.1 CD47-Bot Extra Discussion 7 31-03-2003 12:37
