Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 04-01-2006, 01:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Controlling visibility of cells in Excel
Here's what I want to do in Excel. I want to have a bunch of data (like forces on an object sitting on a ramp) based on the input of something like an angle in degrees from 0-90 in 1 degree increments. I would like to have all 90 rows, one for each angle. But say I want to display the data for only 0-30 degrees. Is there some sort of function I can use where I'll have a cell for "up until what angle do you wish to display?" and then I won't see anything beyond whatever value is input in that cell?
Or maybe I shouldn't say controlling the visibility, but maybe controlling how many times the formula from the first cell is copied down. Or maybe when you input "up until what angle" it will create those cells on its own.
Sorry I didn't describe that well but hopefully you understand what I'm trying to do. I'm not sure if it is possible, but I thought I'd ask.
If you have a question about my description of what I want to do, please ask and I'll try to clarify.
Unread 04-01-2006, 01:55
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Controlling visibility of cells in Excel
Sanddrag,
The spreadsheet I just made up does it in two different ways. The first worksheet uses conditional formatting to check if the cell value is greater than the inputted cutoff. If it is, the text is set to white. This method depends on you having all the data pre-generated.
The second version calculates the data each time. Given an inputted limit and increment (adds some versatility), it generates your list of angles. The formulas are all their for you to play with. I find Excel much easier to learn via re-engineering as opposed to explainations. So I've attached it.
It's late, so it might not be perfect...
Also, there's probably a better way to do it, there always seems to be with Excel.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 04-01-2006, 02:28
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Have you tried the Auto Filter feature? Here's a quick example.
Set up two columns with headers, Angle and Force seem like what you have. Once you have all your data entered, select the columns. Now click on Data->Filter->AutoFilter.
You should now have drop down menus in your header cells. Based on what you were asking, you'll want to select the "Custom" option from the Angle drop down. You'll get a dialog where you can enter your filtering criteria. When you enter your query, the rows that don't match will be hidden and the row numbers for the matching rows will be blue.
To get all of your data back, select the "All" option from the drop down.
To remove the drop downs, click Data->Filter->AutoFilter again.
What I like best is that it allows you to filter based on multiple columns. I use this a lot at work when I need to dig through data logs. I can very quickly show all messages of a certain type that occurred in a certain time interval.
Play around with it a little bit, it should be fairly intuitive.
Hope this helps.
Unread 04-01-2006, 03:00
That's almost exactly what I wanted. However, I didn't like the sort of back door route of using the hidden "A" column. So, I devised a better IF statement to take care of that. Take a look.
Unread 04-01-2006, 03:19
Very nice. I like this new solution better as well. Although Dave's method sounds even better. I've never played with Auto-Filter before, but I am definitely going to in the future.
Unread 05-01-2006, 02:45
I tried Autofilter and didn't get much luck out of it. The IF function method is working perfectly. Go check out what I was up to in my new whitepaper "Object on an Incline Spreadsheet" It also makes one quite tricky but very creative (imho) use of Conditional Formatting and a use of cell data validation.
Excel is a much more powerful program than most people know. I'm glad I'm finally getting a chance to explore it in more depth than just basic arithmetic and graphs.
Using Inventor without Excel jdiwnab Inventor 4 14-12-2005 14:28
MS Excel to CAD daramana Inventor 1 21-01-2005 10:03
Hydrogen Fuel Cells Mike AA Electrical 12 20-11-2004 16:41
