Go to Post I have a bobble head? - Koko Ed [more]
Unread 04-01-2006, 17:00
I_Am_Your_DoG I_Am_Your_DoG is offline
Team Role: Mascot
Rookie Year: 1900
I_Am_Your_DoG is an unknown quantity at this point
CMU green specs?
Anybody what were the specs for the amount of green in RGB format? or is it like green screen color or something like that? also if anyone could add a picture it would be great.
Unread 04-01-2006, 17:43
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: CMU green specs?
I do not have the RGB numbers any more (my ancient laptop crashed and wiped out the pics I took at competition color calibration ), but I do have the YCrCb numbers if you're interested:
Y: 128
Cr: 90
Cb: 108
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 04-01-2006, 21:30
Umm Errr...
They will be different for everyone and must be calibrated on a location to location basis. The color perceived by the camera depends on a number of factors including
  • Type and brightness of light used. Different types of lighting( incandescent, flourescent, halogen, HID) have radically different spectral profiles
  • angle at which surface is viewed.
  • current camera settings (AGC, white balance, etc)
  • Surface texture of paint. Is it applied to the plastic used on the official tetras or is it a mockup wooden tetra? Was it applied with a brush or a sprayer?
  • at what angle are you viewing the object
  • how wide do you want your color window
  • The CMU cams use a pretty crappy CCD. I wouldn't be surprised if there are differences large enough to be considered signifigant between different batches of cameras
It is almost pointless to give out color numbers.
1139 Alumni
Unread 04-01-2006, 21:43
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
  • The CMU cams use a pretty crappy CCD. I wouldn'y be surprised if there are differences large enough to be considered signifigant different in batches of cameras
Also, there's another one that you might not have thought of.
At UCF (Florida), some of the time the outside doors are open, sometimes they are closed, so at different times during the regional, the numbers will vary depending on how the door configuration is. The reason they are open is due to some of the pits being located outdoors so not everyone has to crunch inside of the floor of the arena.
FAHA: Green Paint Ken Leung General Forum 7 09-03-2005 22:47
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
Reputation points SilverStar CD Forum Support 73 26-05-2004 02:14
2004 Motor specs - Part 1 Paul Copioli Motors 12 28-01-2004 17:40
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
