Go to Post I think your robot is lacking in non-threatening, huggable design. - Kevin Sevcik [more]
Unread 01-12-2005, 11:43
TonzOFun TonzOFun is offline
AKA: Chris
FRC #0555 (Montclair Robotics)
TonzOFun is on a distinguished road
Send a message via AIM to TonzOFun
Re: Competition Super Dongle
Originally Posted by Billfred
Besides, the dongle pinout's enough for me. Disable, autonomous. What more do you need?
We were hoping to completely duplicate competition control as much as possible. All you practically need is the pin-out, but we also want to provide power, radio and change team color. In other words, they would plug in competition and be provided everything that happens in a competition. It would be very useful for training new drivers.
Name: Chris Noll || Position: Alumni
Areas of Knowledge: Design, Fabrication, Pneumatics
2005 Awards
Arizona Regional Winners || New York Regional Finalists
New York Regional Website Award || New York Regional Sportsmanship Award
Championship Sportsmanship Award || Brunswick Eruption: Mike's Favorite
Unread 01-12-2005, 12:20
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by sciguy125
Wouldn't it be cheaper just to regulate the battery and feed that to the OI directly?
You don't even need to regulate it, the OI will be happy with 12 V (after all, that's what it gets when the tether cable is connected).
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 01-12-2005, 13:15
Back after 4 years off
FRC #5279
I still dont see why it would be necessary to have a "super dongle" the dongle we use is a box with three labled switches, Auto, Practice and Power. Team color an easily be done just go to radioshack and buy a couple of blue and a couple of red led's. The power would not be any more compact if it was a power supply to the competition port than if it was going to the regular pin for the power. It is impractical for IFI to release anything more than they have done.
If you want to simulate problema and you use less than 4 joysticks then get the pinout for these joysticks and make a switch box that would attach to the pins for yaxis x axis and all of the buttons. Then in the code p4_y could do something like cut power to the motors or rest the circuit breakers. If I remember there are 12 different inputs for each joystick, 4 for the hat 2 each for the x and y axis 2 buttons on top, one button by the thumb and the trigger. by wiring these to switches and assigning a binary number to each possible thing to go wrong you could have 2^12 or 4096 different problems. The software would see what switches were open and what was closed and then simulate the problem. Doing this now would also give you a nice set of switches to use as preprogrammed arm posistions or to use to reset pots in competition. This may be a more practicle use of your time than building a "super dongle"
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-12-2005, 15:26
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Security through obscurity is never a good tactic. Look at a commonly used program that some of you may know, Windows. It's source code is not available to the public. Because of this, it is harder to write virii (because you can't see evident holes, you must find them.) Now look at an open-source operating system, Linux. You could see the code and find holes, but for some reason there are less virii for Linux than for Windows. (Yes, I know it may be because of less Linux users... but my point is still valid.)
If somebody wanted to go through the trouble of making a killer robot, finding the funding, etc. they will go through the trouble of figuring out IFI's pinout positions. Right now they are just penalizing teams that may want to use it for legitimate, helpful, purposes... such as TonzOfun.
Open the protocol/pin diagrams.
http://www.mikesorrenti.com/
Unread 01-12-2005, 15:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Actually, it's very frequently a good tactic, so long as it's not the only tactic. Why make it easier for someone to compromise the system? Just make sure that if it's guarding something important, there are other measures to prevent unauthorized access.
As for the Windows-Linux analogy, I don't think that that really helps your point. You've pointed to a correlation, but haven't established causation—there are many more facets to that issue that should be considered.
By the way, it's not "virii", it's "viruses", both in English and Latin. Here's why. (Scroll down...the article tackles other, related issues first.)
Unread 01-12-2005, 16:22
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Originally Posted by sanddrag
Full auxiliary channel access
I agree with you. There is a lot of crud on the 900mhz band, and to be able to switch to whatever channel works is sometimes invaluable.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 01-12-2005, 19:43
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
No.
The communication protocol between the Arena Controller and the OI is proprietary and confidential. Knowledge of this would enable a team to manually switch to competition channels. This would COMPLETELY compromise the integrity of the FIRST competition.
The pins that have already been released are the only ones that perform any useful functionality. Everything else is controlled during the communication between the 2 processors via a serial link, and as such, is the protocol NOT for release.
Yes.
Someday, some FRC participant with too much time on his hands will “crack” the code, and reverse engineer the communication protocol. From that point forward, no matter how much we try, we may not be able to protect the integrity of the communication link between you and your robot. Although we continue to monitor communication with our scanners to protect competition integrity; we keep things proprietary for your protection.
JVN
Unread 02-12-2005, 07:20
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
That's true, but the power adapter and the tether handle much less Amperage then the battery is capable of putting out. Personally, I'd either want it regulated or passed through a fuse that was very small.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 05-01-2006, 10:49
RoboGeek RoboGeek is offline
AKA: Matt Kinnison
#0063 (The Red Barons)
RoboGeek is an unknown quantity at this point
Send a message via Yahoo to RoboGeek
I have tried this many times and the OI will not power up with 12 volts out of the competition batteries for some reason no matter what I try however the backup batteries from 04 & 05 are a perfect rechargeable power source for the OI.
Unread 05-01-2006, 11:16
GET IT ON!!
I believe that the OI operates on 9V not 12V, but I am not exactly sure.
Rhode Warriors
Unread 05-01-2006, 11:29
Manoel's Avatar
That's weird. Even though it's rated for 9 V, you can power it with 12 V with no problem. Are you using the correct polarity? See this post for more info.
Let us know if it still doesn't work.
Brazilian Machine
Team # 383
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman General Forum 85 08-01-2005 00:16
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman FIRST E-Mail Blast Archive 0 05-01-2005 16:46
Looking from a different point at "Fixing" punarhero General Forum 27 18-03-2003 18:41
SCRRF 2/16/03 Sectional Competition Redhead Jokes Southern California Regional Robotics Forum 0 26-01-2003 01:33
yellow dongle Ryan Foley Electrical 1 24-01-2003 15:41
