Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 05-01-2006, 15:36
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Re: **FIRST EMAIL**/Advance Materials List and Autodesk Virtual Kit of Parts Informat
What about multiple ramps, maybe elevated goals in the corners or something, like the Vex game for this year. That could make things interesting.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
  #32   Spotlight this post!
Unread 05-01-2006, 15:39
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: **FIRST EMAIL**/Advance Materials List and Autodesk Virtual Kit of Parts Information
I was thinking the same thing actually. The )T( thing would be a pain in the hiney to get up on though, if you really think about it.
-Sir Francis Bacon
-Albert Einstein
  #33   Spotlight this post!
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Manoel
... I believe the aluminum diamond plate is more for decorative purposes than anything else...
I don't think so. If it was just decoration, I think that they wouldn't put in on the list. There must be some significant interaction with the aluminum plate or they would just do what they did two years ago with the risers for the chin-up bar -- have folks make the practice field out of something esle.
Also, they must plan on the 4X8 sheet being used whole. Even at 1/16 thick, I think cutting this plate in half would be more than many teams could accomplish without some pretty ragged edges.
Joe J.
Team #88, TJ2
  #34   Spotlight this post!
Unread 05-01-2006, 15:40
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
There are a LOT of 2x4s here 17 8ft long each and 2 10 footers. If this is half a field like in previous years this is big. Also I don't think FIRST would use 1/8 polycarb for a ramp as mentioned. It's too thin for safety. I'm thinking transparent scoring column of some sort.
I figure the 4 3/4" plywood sheets are load bearing platforms, the 2 1/4" are a player station and the 1/2" is either a wall or platform that sees lower impact.
I have to say after last year's move to simple set up and low cost I'm kind shocked at how extensive this is.
Pete
  #35   Spotlight this post!
Unread 05-01-2006, 15:42
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Originally Posted by team222badbrad
Cough, Cough, GUM RUBBER!
Shhhh It's a secret.
  #36   Spotlight this post!
Unread 05-01-2006, 15:43
ScottM ScottM is offline
AKA: Scott Martin
FRC #0001 (Juggernauts)
ScottM is just really niceScottM is just really niceScottM is just really niceScottM is just really niceScottM is just really nice
There's something missing......green paint
  #37   Spotlight this post!
Unread 05-01-2006, 15:46
FRC #0306 (CRT)
Joe J.
In the pdf, it specifically states that smaller sheets are available from Homedepot. If an intact full sheet was needed, they wouldn't point us to a place to buy smaller pieces. However, it may be somesort of flooring, in which smaller pieces would not make a difference. I bet that the flooring on part of the field is diomond plate.
-Sir Francis Bacon
-Albert Einstein
  #38   Spotlight this post!
Unread 05-01-2006, 15:52
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Originally Posted by Andrew Blair
In the pdf, it specifically states that smaller sheets are available from Homedepot. If an intact full sheet was needed, they obviously wouldn't point us to a place to buy smaller pieces. However, it may be somesort of flooring, in which smaller pieces would not make a difference. I bet that the flooring on part of the field is diomond plate.
I think what he's saying is that wherever the diamond plate is, it will be a 4 x 8 area.
the reason they point you to a place to buy smaller sheets is because not everybody lives in an area near a diamond plate retailer. but home depot is everywhere.
one thing i noticed that isn't there...mailboxes
Collin Fultz
  #39   Spotlight this post!
Unread 05-01-2006, 15:54
Does the AL plate strike anyone else as the $58 item from the other thread given original price of $110?
  #40   Spotlight this post!
Unread 05-01-2006, 15:59
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
with only 8 carriage bolts the primary structure could not be vary large. ramps need bolts to hold them together.
we have a lot of nails, which are needed to put together several smaller objects.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
  #41   Spotlight this post!
Unread 05-01-2006, 16:02
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I agree, it is quite a suspicious candidate. It definitely sounds like the Washington FIRST guy was able to cut a deal with a local metal supply shop. I also agree with Dr. J, this aluminum will be used intact and not cut.
  #42   Spotlight this post!
Unread 05-01-2006, 16:06
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Joe J.
Yes, quite possibly. I like this new theory of aluminum and polycarbonate flooring better than my old one!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #43   Spotlight this post!
Unread 05-01-2006, 16:07
FRC #0306 (CRT)
I don't know how the 2003 ramp was put together, but there are a whole bunch of screws in the materials list. My guess is, the carriage bolts hold the AL plate on and the structure is screwed together. Or, the structure is screwed together, and the carraige bolts are in a few places to allow easy takedown of the field.
However, aren't there better bolts than carriage for attaching something like that diamond plate?
-Sir Francis Bacon
-Albert Einstein
  #44   Spotlight this post!
Unread 05-01-2006, 16:09
AKA: Dr. Joe
FRC #0088 (TJ2)
Does anyone know if the diamond plate in the spec sheet 3003-H22/24-TP looks like this:
or does it look like this:
The difference in terms of traction is night and day.
Just wondering.
Joe J.
Team #88, TJ2
  #45   Spotlight this post!
Unread 05-01-2006, 16:12
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Heres the list of the 2005 Field Elements for comparison http://www2.usfirst.org/2005comp/200...terials_r9.pdf however its the post kickoff edition, so ignore the stuff in Bold and you have a similar hint.
Overall the field is cheaper per item in the 05 game, however there were more parts. So could we see multiple ramps assembled this year? Maybe 3 ramps, stretch accross the field?
**FIRST EMAIL**/Autodesk Software Donation, Inventor Training and Awards Information Beth Sweet FIRST E-Mail Blast Archive 3 05-10-2005 23:34
