need help with ifi asap!!
i tried to put the new version of ifi onto a laptop problem is ifi is big and all i can use between 2 computers are floppies. i tried about 3 times and did everything i could to make sure that all my files are there and they are but it says some are missing. any ideas of how to get ifi onto the laptop with only floppies???
Re: need help with ifi asap!!
no internet and if the kit has it it'll be on a disk not a floppy
do you mean IFI Loader or MPLAB
IFI Loader is so small that you can move the individual files via floppy or you could always network the 2 computers together and send it that way |
magically i have a new desktop that does have a serial port, most people don't believe that. if u have info on doing that please tell me!
#7
Get something like winrar and archive it all, and tell it to split it in to 1.44mb chunks
Copy all the chunks and extract the first one, winrar will automatically proceed to extract them all and reassemble it. |
#8
Get a serial or parallel crossover cable and then transfer the file over the cable. I use Total Commander and a parallel port crossover to do the job.
Regards, Mike |
#9
i got winrar now how do i do it?? and do i need winrar on the other computer?
#11
haha nvm i got it!!! yay go me!!! now lets just see if it works right??
#12
new problem.. i got ifi on and opening but when i go to chose a hex i get a fatal error message help please asap!!!
#13
ifi error!! need help now!!
i finally managed to get ifi loader onto my laptop but now i have another problem.
in the bottom corner of ifi loader it says code error and when i go to choose a hex file it comes up with a fatal error. i searched high and low for system requirements for ifi loader and could not find anything. could this problem possibly be because i am trying to run it on windows '95 or is it something else? |
#14
I have never used IFILOADER with Win 95 but i know it works in 98
try and uninstall it on that computer and defrag the HD then install it again, sometimes files just dont copy right, also make sure the floppys dont have any currupt data points, i checked all of mine a month or so ago and over half were messed up |
| Building an arena controller | CJO | Control System | 32 | 29-03-2005 07:04 |
| IFI Loader and PROG button | Dave... | Programming | 3 | 20-02-2005 12:03 |
| IFI Loader usually hangs midway thru load | gnormhurst | Programming | 4 | 04-02-2004 11:40 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Bug in IFI Loader | rwaliany | Programming | 2 | 06-01-2004 21:26 |
