Go to Post Have you hugged your programmer today? - Gabe [more]
Unread 24-12-2005, 02:12
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Hair and Fur in MAX 8
I noticed that the included MAX 8 tutorials are painfully sparse on animating with their new Hair and Fur WSM. I thought this would be a good place to share any information we learn about it. Here's what i've found out:
1) in order to render hair motion, you must precalculate it
2) hair collisions are PAINFULLY hard to do and require lots of guide splines
3) spacewarps such as wind are great tools for getting effects with hair, but they take quite a bit of tweaking to acheive the right effect
that's all i can think of right now. if anyone's figured out how to make the hair correctly collide with it's growth object, let me know!
-Nuttyman54
Unread 26-12-2005, 19:24
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: Hair and Fur in MAX 8
The hair and fur modifier is awesome, that was just on my first few attempts too so it's quite easy to create a picture with fur... but I'm sure animating with realism would be a whole different challenge.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 26-12-2005, 19:28
Nuttyman54's Avatar
Mentor, Tactician
ahh wait until you try animating...i can't get the fur to collide w/ the ground...or much anything else realistically
Unread 28-12-2005, 06:24
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
the rendering of the fur and hair is just a massive amount of details for our pc
we just got a new oen this year, and the hair and fur triple the time it takes
a 10sec clip one of the animation team did, with hair... of just a guy playing a piano, took about 8 hours, dosent matter how you split it
when it renders the hair and fur, it's just horrible
any thoughts or ways to reduce rendering time for hair and fur?
or just making the render itself quicker?
thanks in advance
Unread 28-12-2005, 12:43
Is there some way you can net render with multiple computers involved? If you have that capability, it would allow multiple machines to work on your render job and speed up the process.
Also, any less detail will mean lower render times. High quality stuff takes a long time unfortunately.
Unread 28-12-2005, 12:54
AKA: Nimrod Amir
Team Role: Animator
well we do have a network of 15 computers, even over 40 in the overall school network
, unfourtanetly we do not know how to hook the render up so it's all toghether working
with eachother
how do I do this?
Unread 28-12-2005, 17:14
I have personally never had to do a Net Render, so I'm not sure. But I found a site that hopefully will help you out: http://raven.cc.ku.edu/~acss/netrender/netrender.htm
Good luck
Unread 28-12-2005, 18:56
Nuttyman54's Avatar
Mentor, Tactician
Max 8 ships with Backburner 3, which allows you to use up to 999 CPU's if they're all networked together..the limitation being that you've got one CPU crunching each frame, so if you've got 80 frames, it doesn't matter if you've got 80 CPU's or 800 CPU's, it'll still take the same amount of time.
As for reducing the render time, you can try reducing the number of hairs and increasing the number of hair passes by the same proportion. (IE reducing 9000 hairs with one pass to 3000 and 3 passes) Also, how many lights do you have illumination/shadow casting on the hair? It could help to exlude some of the lights from illuminating the hair, and using dedicated spotlights for the hair. Also, turn off shadow casting on any lights illuminating the hair, as it will drastically increase the render time. Hope that helps!
Unread 04-01-2006, 00:39
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
My experience in the past with collision objects, the more detail the objects the more accurate the collision will look- but that also increases the render time. So the more you want to cut back for rendering sake- the less realistic motion effects will look. (When I say detail, I mean segments and such- The computer will have more trouble calculating accurate collisions in a theoretical surface (ie the area between points). The accuracy comes when a vertex collides. I don't yet know the object creation parameters for the new Hair functions- but this is what its been like in the past doing - hair, toothbrush, grass, etc.
Net rendering is the way to go. If you have access to multiple computers, go for it. Of course it will render one frame per CPU! but that means it will simultaneously render that many frames as opposed to one at a time on one computer. When we first setup net rendering- it was taking us a few days to render our test animations- then we were able to run full resolution finals of our entire animation in one night (that included working late and starting early the next morning.) So we were able to run the entire thing in several hours instead of days.
Unread 05-01-2006, 20:59
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
that's what i did. 17634 strands. 5 passes. about 2 min. to render. no lights.
FUUUUUUUUUUUUUNNNNNNNNNNNNNN!!!!!111!!111!!!1!1!1
Unread 05-01-2006, 21:13
Nuttyman54's Avatar
Mentor, Tactician
so has anyone (besides me) actually tried animating it yet? let me know how it goes...i'm still trying to get it to respond to wind correctly
Unread 09-01-2006, 02:30
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
there is a way to make it render faster...
Pentium D processor or Athelon duel core....
aha. i found a few ebooks on 3ds max animation and nobody has helpful hints on hair animation. so i would appriciate some help as well. nice thread here.
Unread 09-01-2006, 07:50
Cyber Punk 234's Avatar
Cyber Punk 234 Cyber Punk 234 is offline
John Carter
AKA: John
None #0234 (Cyber Blue)
Team Role: Webmaster
Cyber Punk 234 is on a distinguished road
Send a message via AIM to Cyber Punk 234 Send a message via MSN to Cyber Punk 234
cool fur.
Unread 09-01-2006, 08:39
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
This plugin is definately not for realism... I have had Max 8 since a while before the teams got it shipped, and it is dang-near impossible to animate or model hair with any sort of realism... I think that I'm just going to stick with max 7 for any hair in my personal animations, the Turbosquid Plugin is much easier to use and renders much faster. The Styling option in max 8 however, is amazing... it is much easier to make cartoony hair-styles with.
Unread 09-01-2006, 14:55
Nuttyman54's Avatar
Mentor, Tactician
You're talking about the Ornatix (or whatever it's called) plugin right? i've heard that's the best. From what i've seen, Shave and a Haircut (what the Hair and Fur is based on) works much better with Maya's dynamics engine than Max's, but we're stuck with what we've got...
