Go to Post They knew that the number of gracious, professional, make-your-grandmother-so-proud-she-will-puke moments of exemplary behavior by the teams would far outshine any minor mistakes or incidents of less-than-perfect decorum. - dlavery [more]
Unread 05-01-2006, 22:29
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: capacitors in parallel with motors
Adding filter caps will almost certainly cause problems. If you add a big enough cap it will probably make your controls sluggish...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 05-01-2006, 22:42
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
I think that in order to be large enough to make sluggishness a cause for concern, the cap would be HUGE. I don't really want to spend the time on the math, but I suspect that it would have to be far larger than most readily available caps.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 05-01-2006, 22:49
phrontist's Avatar
Proto-Engineer
Now that I think about it, yes, yes it would have to be. Still, not a great idea.
Unread 06-01-2006, 12:30
Andy A. Andy A. is offline
Getting old
FRC #0095
A capacitor would only cause a sluggish response if it were in series with the motor. In that case, the motor would at times see a reduced voltage as the capacitor charges, and at other times see a higher voltage then the victor is outputting as the capacitor discharges. It would have to be a very large capacitor to be noticible, which means that it would probably be of the electrolytic kind. And we all know how much they like reverse current when you try to drive backward! They are used on large motors, such as in Electric cars. Because the starting current on a large motor is so high, it can draw the supply voltage very low and give poor performance. A large capacitor (or several smaller ones) can be used in series with the motor to keep the voltage from dropping to severely under acceleration.
If the capacitor were in parallel, bridging the positive and negative terminal, the function would be to filter out all the noise that a motor produces. They are common on DC motors. Typically, they are very small, on the order of 1uf or smaller, and of a type that isn't harmed by reverse current. My guess is that most of the motors we use already have filters installed in side of the motor can. In any case, it doesn't matter because the Victors are not going to mind either way.
-Andy A.
Unread 06-01-2006, 13:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
I do not think that there are any motors that have a cap already built in, but i could always be wrong, and the VICTOR is a motor controller designed specifically to deal with providing power to a motor almost completely isolated from the rest of the cicuitry, that said i'm pretty sure that whatever company manufactures them has engineers who have thought of the ways that they could best reduce electrical noise caused problems when the VICTOR is used correctly
KK4KQO
http://voltair.us
Unread 06-01-2006, 14:50
Capacitors are not only not needed but also illegal. The Speed controllers have built in noise suprression to prevent any nasties from ending up back at the RC.
The effect of haniing a big cap across the motor just compounds the start current and run responses. Don't forget that a capacitor looks like a dead short when discharged. When a capacitor is charged to some voltage and the supply voltage is reversed, the charge must be removed before the new voltage will charge the cap. This precludes using electrolytic capacitors which can't have a polarty reversal without spectacular self destruction. Some motors (in the far distant past) have had small caps installed, internally, across the brush assembly to try and quench brush noise. Currently supplied motors do not have any of these internal components to my knowledge.
capacitors on motors John Gutmann Motors 8 26-07-2005 23:06
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 12-01-2005 09:04
