Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 05-01-2006, 23:25
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Re: **FIRST EMAIL**/Advance Materials List and Autodesk Virtual Kit of Parts Informat
The lexan isn't likely to be used for the walls of a ramp..they are only 1/8". The side walls for 2003 were 3/4" I believe...perhaps 1". Either way, they were thick. Being a surface to see a FIRST logo under makes sense, and the traction on them isn't too terrible for FIRST bots (VEX bots are another story...we had lexan ramps in our Uber Tuber game and only 2-3 out of 21 teams could get up them).
The diamond plate is really driving me crazy.
Those 10' pieces of lumber could be used in conjuction with some of the 2x4s to make a ladder. For what...well...er..hmmmmmm.
Kev - who can't wait for the sound of a few thousand palms smacking a few thousan foreheads in just under 36 hours.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
  #92   Spotlight this post!
Unread 05-01-2006, 23:32
1075master's Avatar
1075master 1075master is offline
SLEEP IS POINTLESS!!!
AKA: John Nelson
FRC #1075 (Sinclair Sprockets)
1075master is an unknown quantity at this point
in '04 lexan was used on the top of the middle element and the steps were made out of diamond plate. arg this is hurting my brain!!!
2004 && 2006
-driver,head design, head build, secondary programmer
year >= 2007 && year <= 2009
-mentor in every aspect
  #93   Spotlight this post!
Unread 05-01-2006, 23:43
Nope. HDPE (High Density PolyEthylene) was used on 2003's ramp as the top surface, 2004 had HDPE on top of its platforms, and the diamond plate was on the sides of said platforms.
What's really killing me is the sheer volume of lumber. I count three different types in two lengths, one of which (2*4*8ft) has a quantity of 17. And then you throw in three thicknesses of plywood. NO casters, PVC, flanges, magnets, or anything else that is unusual, except for the amount of wood.
Let's not forget that 2*whatever (usually 4) or plywood is a common substitute for diamond plate, depending on the application, but if there is diamond plate you have to maneuver on, forget it, you're better off with diamond plate.
  #94   Spotlight this post!
Unread 05-01-2006, 23:46
Billfred's Avatar
Billfred Billfred is offline
Not quite. The small steps in front of the stationary goal in 2004 were diamond plate, if memory serves me right. (And even if they weren't, it was definitely aluminum.)
Everything else, though, seems accurate.
  #95   Spotlight this post!
Unread 05-01-2006, 23:51
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Originally Posted by M. Krass
You can't get two 5' long pieces of wood from one 10' long piece.
I don't want to sound like a smart butt but I don't understand your response. I don't know about you but I can rip a 10' 2x4 on my table saw into 2 10' lengths if I cut down the middle. I can cut at an angle and get anything in between (i.e. two 6' long 2x4s with pointed ends). I could even cut two 10' long triangle wedges if the 10' 2x4 was cut on a diagonal. I make no claims that anything I cut will be straight though. My point is I'm not assuming anything about how we may or may not cutup and use any of the material on the list.
  #96   Spotlight this post!
Unread 06-01-2006, 00:00
FRC #0701 (RoboVikes)
Polycarb - The see-through aspect is definitely important... I like the cylindrical idea... I think the Lexan will be rolled into a cylinder and will contain scoring objects, which must be retrieved from inside (?)
either that or maybe
Diamond plate - I think it will laminate over a ramp of some sort.
2x4s - There is just SO MUCH lumber, I have to agree: there will be some curved structure, sheeted w/ the luan, this will require ALOT of 2X4s for adequate support. perhaps even two angled ramps with a curved ramp in the center ?
Like this but of course less steep
/U\
Bolts, 1x3s and 1x5s - These have totally stumped me (esp. the 1X5X8!)
Team 701
  #97   Spotlight this post!
Unread 06-01-2006, 00:05
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Could you rephrase that so we can understand you? And HDPE is plastic (look for milk jugs for an everyday example) and fairly slippery; that's why it was used as a driving surface. If they wanted slippery, they'd have put HDPE on the list, but Lexan is clear and less slippery.
Maybe they weren't looking for super slippery; this year's game may be so devious that even a mildly slippery surface will give us enough trouble.
In 2004 the stairs were made of diamond plate, the intermediate platforms (red and blue) were HDPE and the top one (under the chin up bar) was polycarbonate. The FIRST logo was visible through it; that way you get slippery and purty, something the GDC really likes
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #98   Spotlight this post!
Unread 06-01-2006, 00:39
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Originally Posted by ScottM
There's something missing......green paint
So I'm guessing no CMUcam cuz theres no green paint. hm...so whats Montanas green heights?
Team 2522 | Mentor
Formerly of Team 22 and Team 4
  #99   Spotlight this post!
Unread 06-01-2006, 00:50
Ha. I wouldn't rule it out just yet. Who knows what's coming in the kit.
  #100   Spotlight this post!
Unread 06-01-2006, 02:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: **FIRST EMAIL**/Advance Materials List and Autodesk Virtual Kit of Parts Information
I was in the FIRST IRC chat just now, and there was this guy in there named sanddrag, and he made some predictions that sounded pretty good.
  #101   Spotlight this post!
Unread 06-01-2006, 02:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Well, of course, but wouldn't it be a bit silly for FIRST to have us buy 2x4s only to make them into 2x2s?
I was just pointing out that you can't get two 5' 2x4s from a 10' 2x4, but even that's not true, apparently. As with their width and height, I'm told, 10' lumber is actually not 10'. It's a bit longer. Or so says the guy who works at Home Depot.
(This is why I hate lumber.)
--Madison--
...down at the Ozdust!
  #102   Spotlight this post!
Unread 06-01-2006, 02:42
Pipe is nearly as bad. One day they (yes, the mysterious "they") need to redo the naming/reference system on lumber and pipe.
  #103   Spotlight this post!
Unread 06-01-2006, 02:44
Madison's Avatar
FRC #0488 (Xbot)
...and heaven forbid that you confuse pipe and tubing. Oh man.
--Madison--
  #104   Spotlight this post!
Unread 06-01-2006, 03:56
varcsscotty varcsscotty is offline
Programmer
FRC #1571 (Braughtswurst)
varcsscotty is an unknown quantity at this point
are you sure it's longer? i thought it was approx. 1/16th shorter because the mill has to cut it down so some of it becomes sawdust....not that it makes a huge difference... but it might to my engineer team membes
  #105   Spotlight this post!
Unread 06-01-2006, 05:47
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Very, Very difficult to roll a sheet of Lexan, even 1/8"
**FIRST EMAIL**/Autodesk Software Donation, Inventor Training and Awards Information Beth Sweet FIRST E-Mail Blast Archive 3 05-10-2005 23:34
