Go to Post There is always more than one way to design something. - Dave Scheck [more]
Unread 02-01-2006, 22:41
robohippo robohippo is offline
robohippo is an unknown quantity at this point
Creating linear motion
After seeing the pictures of the tetra grabbing 2 stage lift, I was wondering how to attach a structural piece to a chain so that as the chain moves horizontally, it provides linear motion. Obviously, limit switches would be neccesary to prevent the part from being sucked into the sprockets. So how do you experts do it?
Unread 06-01-2006, 21:32
teh_masterer's Avatar
teh_masterer teh_masterer is offline
ub3r 1337 R0b0 d00d
AKA: Chewy Hollaway
FRC #1529 (Cyber Cardinals)
teh_masterer is an unknown quantity at this point
Re: Creating linear motion
we tried it with the tank treads and drilled a hole in the middle of one of the tracks and bolted into the slide
Pwning n00bs since 2004
my hands are shakin'
my hearts a beatin'
im still shootin'
and im still gettin headshots!!!
BOOM, HEADSHOT!!
BOOM, HEADSHOT!!
Unread 06-01-2006, 21:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
robohippo, can you link us to that picture? I'm not exactly clear on what you are describing.
Unread 06-01-2006, 22:28
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
I think he is refering to this pictures:
http://www.vexrobotics.com/index.php...le?user_id=234
http://www.chiefdelphi.com/forums/sh...ad.php?t=40388
those are the profile with several pictures of their robot.
and regarding to your question I hope this link will help you with the way the system works:
http://www.vexlabs.com/conlift.shtml
thats basically how it works with a few expections
cheers
~gdo
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 07-01-2006, 01:21
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
cheers
~gdo
Yup, that's it.
For a single stage elevator, you can simply make a loop of chain and secure your linear motion part to a single point along this chain. (Much like a garage door opener.) Here is how I attached the chain to the elevator slide when the Triple Play Robot was only a single stage elevator.
For the multistage elevators, things start getting more complicated. Here are a few of the pictures from this post:
The way the multistage elevators work, is that the chain loops through every stage of the elevator. They are also attached to a fixed position somewhere on the last (uppermost) stage of the elevator. I attached the chain to the sprocket itself by zip tying the chain in place. To make this even more efficient, try locking the sprocket from rotating as well. (The sprocket will not rotate much (maybe 10° or so) if the chain is zip tied to it, but it works better if this sole sprocket is locked into a single position.
(See this link from gdo's post for a diagram of the Continuous lift concept.) In that diagram, if the motor in the base of that robot was to start pulling on the red chain/rope, the chain will shorten. Since it is attached at the other end, the elevator will have to find a way to make get shorter. It does this by beginning to pull up the uppermost stage first. (Because this stage is the lightest). It will then proceed to do this until all the available "slack" is used up, resulting in all the stages of the elevator being extended.
But there are a few very important things to keep in mind when developing a multistage elevator. In the pictures of the beta stage of my "Space Elevator" Vex Robot, I used elastic bands as tensioners, because I did not have the geometry of the elevator perfect at that point. When building the elevator, any of the segments of the chain that actually "shorten" or "lengthen", such as the green ones in the picture below, must be in EXACTLY the same plane as the direction of the elevator. In other words, the chain in these green segments must be parallel to the direction of the elevator.
If these green segments are not perfectly parallel to the direction of the elevator travel, they will essentially form a triangle's hypotenuse. As these green segments become "shorter" and "longer", the change in triangulation of these green segments will make your chain become unbearably loose or so tight that it snaps. In the above pictures of the "Space Elevator", all the "green segments" were all done correctly, except the last return section in the front. Hence the elastic bands. But after a quick modification, I fixed this issue (no more elastic bands required!) and the elevator worked perfectly. (You can kind of see the new modification in this picture. I'll get a better picture online tomorrow, as all my Vex pictures are on my other computer right now.)
Art Dutra IV
世上无难事,只怕有心人.
Help with motion detector chantilly_team Programming 13 31-01-2006 22:10
Flywheels achieving linear motion mechanicalbrain Math and Science 22 31-01-2006 20:27
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Building a Clock with Periodic Motion IMDWalrus Math and Science 15 24-03-2004 16:48
Thanks to Metal in Motion and Operation Oxidation! Zack Ghahramani Thanks and/or Congrats 0 09-03-2003 17:18
