Go to Post There was a manual? - Taylor [more]
Unread 07-01-2006, 14:07
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
2006 Motor Specs
Who knows where the 2005 motor specs can be found ? last year they were in the manual this year i dont see them there.
Thanks.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 07-01-2006, 14:09
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Re: 2006 Motor Specs
it was explained in the webcast. 36 teams are making the specs and will be publishing them
Elgin Clock's Avatar
FRC #0237 (Black Magic)
http://www.usfirst.org/robotics/2006...s.htm#Section5
Under
Other Important Documents 2006 FIRST Robotics Competition Specification Sheets
edit: Yes, that is correct., but those will be "real world applications" for FIRST as opposed to the data shown in my link above which is directly from the manufacturers of said parts.
Unread 07-01-2006, 15:10
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Fairly accurate motor speeds: (no load)
CIM: 3590 rmp
Larger CIM: 2180 rpm
Fischer Price: 10,280 rpm
Found using a precision strobe light with adjustable ticks per minute. Accuracy is about +- 0.5% on the motor speeds.
Have fun, all.
Unread 07-01-2006, 15:19
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Typical tolerances on motors are +/-10-15% and that doesn't include variations due to voltage.
I have never designed a motor/gearbox application where the performance of the motor had to be within .5%, certainly never in FIRST...
For what it is worth.
Joe J.
Team #88, TJ2
Unread 07-01-2006, 16:23
Joe J.
Joe, you are totally right.
However, what I mean is that the speed of the motors I got were measured to within 0.5% accuracy. There probably is a lot of fluctuation in the speeds of motors across the country, I was just letting people know that my equipment is quite precise.
Just to clarify
Unread 07-01-2006, 16:25
AKA: Dr. Joe
FRC #0088 (TJ2)
I have not had a chance to look at everything but from what I can tell so far these are the motors in order of wattage:
  • 4 - Old CIM (340W)
  • 2 - New CIM (270W)
  • 2 - Fisher Price motors (170W)
  • 1 - Bosch Motor (70W - based on old 12V specs of 35N-m stall & 75RPM Free)
  • 2 - Globe Motors (50W)
  • 2 - Denso Motors (25W)
  • 1 - Mabuchi Motor (15W)
Am I missing any? I suppose there is the servos that are probably more powerful that 1W*, but they are harder to get continuous power out of since they don't automatically keep putting out work, they only do continous work if your program does some fancy footwork to keep the things moving (winding a mechanism or something I suppose is possible, but probably not worth the bother).
There is an very nice, rich set of motors for teams to pick from. Well done FIRST.
By the way, I am in the process of evaluation THESE MOTOR/GEARBOXES from BaneBots.com. For about $40 you can get gearboxes that the Fisher-Price and the Mabuchim motors will just bolt to. They come in a variety of ratios (5:1, 16:1, 20:1, 25:1, 64:1, 100:1, 256:1). The gearboxes have nice mounting points and long, easy to access (and support) D'ed shafts. And I just talked to them yesterday, they have 1000's in stock. Look for my recommendation or my non-recommendation early next week. I have no connection to these guys at all, I just found them on ebay a while back while looking for stuff for Robotic Amusements.
Joe J.
P.S. By the way, I have just found a table in this document that I believe is in error. It has the peak power of the FP motor over 300 Watts. This does not match the specs in the spec sheets or even the specs in the rest of the table in the same document. I believe my numbers are correct. Also, the Bosch and the Globe are listed as non-12V specs you have to scale the power ratings accordingly to get apples to apples comparisons.
*this message was written before I had corrected an error in converting g-cm's to N-m . I had the Mabuchi at 1W, when the motor is actually 15W or so. I have since went to the hitecrdc spec site for the 323HD servo. If I have not made another calc error, the servo motors are able to put out about .5W or so if you can load them at their 6V peak power point -- not exactly what you would call a real workhorse.
Team #88, TJ2
Unread 07-01-2006, 21:15
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
CIM: 3590 rmp
Have fun, all.
Something's wrong here. The old CIM's have a no-load rpm of around 5300 rpm and the F/P are 20,000+.
Team 1062, The Storm, 2003
Unread 07-01-2006, 22:52
I'mwithstupid^'s Avatar
I'mwithstupid^ I'mwithstupid^ is offline
I'mwithstupid^ is on a distinguished road
could his motors have been worn down to those low rpms?
Unread 07-01-2006, 23:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Not if he was testing one he got out of the KOP.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2006, 00:19
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Are the the specs pointed out by Elgin at
http://www.usfirst.org/robotics/2006/2006specsheets.htm
accurate and reliable enough to start designing.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 08-01-2006, 00:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Which begs the question, are the old ones legal? Because they're (apparently) different. Same model number, though; would it have hurt to call it FR-801-002, if it were different?
Edit: I see the spec sheet for 2006 is unchanged; so someone should verify the speeds with their motors, old and new.
Unread 08-01-2006, 03:09
I tested a 2004 CIM with the same method, and I get 5320 rpm, which sounds normal. You can actually hear the difference in rpms between the old and new motors.
Unread 08-01-2006, 13:51
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Joe, which of the 20:1 gearboxes would mate with the FP motor? Would I need to replace the pinion? Does Bane's pinion mate with the FP shaft?
Thanks!
Unread 08-01-2006, 19:56
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks!
Go Here too see the answer
Good Luck,
Joe J.
Team #88, TJ2
PIC18F8722 - New 2006 RC MPU, 4x more program memory! kmcclary Programming 16 08-01-2006 14:22
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
**FIRST EMAIL**/Welcome to the 2006 FIRST Robotics Competition Season! Rich Wong FIRST E-Mail Blast Archive 0 06-09-2005 19:19
New Regional in Europe in 2006 unapiedra Regional Competitions 49 26-05-2005 00:07
Teaching "C" to 2006 students?? cbolin Programming 28 18-05-2005 12:10
