Go to Post Improve yourself. Try not to tear others down. - Tom Line [more]
Unread 06-12-2005, 11:57
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Cool Square Wheels?
Well this is definitely something I would have never considered but in retrospect makes allot of sense. square wheels actually give an overall circular rotation to the robot. My question is this, anyone interested in making a square wheeled FRC robot? Also I wonder how well this would work on stairs?
Unread 06-12-2005, 12:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Square Wheels?
That would be one bumpy drive. I suppose it might have some sort of advantage on stairs (only guessing here) but not a lot, and especially not made out of something like the slippery plastic shown in the picture. It would take more torque to get moving than with round wheels.
For climbing stairs, I think whegs are a good way to go. Except they require lots of torque, and the performance on flat surfaces is sacrificed.
Unread 06-12-2005, 13:01
Re: Square Wheels?
Triangular wheels would be a 25% improvement over square wheels.
For each rotation, there would be one less BUMP !
Unread 06-12-2005, 13:10
Re: Square Wheels?
And linear "wheels" would be a 33% improvement over triangular wheels. Only two bumps per revolution!
Unread 06-12-2005, 13:11
Re: Square Wheels?
Actually from reading the article a I understand it their is very little bump at all. It has to do with the fact that their is a rotation of corners toching the ground. Interesting concept really. It reminds me of how whegs work.
Unread 06-12-2005, 13:13
Re: Square Wheels?
So mathematically, the best wheel design is a single arm: one bump per revolution.
BTW, goto ebay and search on "matt mason space crawler"
a very popular toy back in the late '60s
Unread 06-12-2005, 14:17
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Square Wheels?
Square wheels will not provide rotation like that of a disc. The center of rotation does not move linearly, but in a cam motion -- a bit like a spiral, but not repetitive. Whegs, which I assume is a combination of wheels and legs, might appear to create circular motion as well, but in reality would form a similar cam-like path. The whegs simply rotate fast enough to minimize the time the machine has to fall between legs. The faster they spin, the less 'bump' their appears to be.
The 'square-wheeled' machine moves due to a shift in its center of mass and thus, requires specially designed wheels to the shift of mass causes each corner of the robot to fall sequentially.
I can't imagine how this would be useful to a FIRST machine at first glance
--Madison--
...down at the Ozdust!
Unread 06-12-2005, 14:30
Re: Square Wheels?
sorry I misread part of the article. The idea behind this is not just the square wheels but the fact that no motor is directly driving them. All motion of the wheels is accomplished though shifting the weight of the robot and a little help from gravity. The idea applies in that you can control multiple objects (and with more things then just wheels) without direct contact. Imagine designing a drive train that changes gear ratio when tipped. Sorry about the fixation on the wheels.
Unread 17-12-2005, 23:28
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
Re: Square Wheels?
Oval wheels....One bump per Revo.
Unread 17-12-2005, 23:38
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Square Wheels?
I think the way square wheels would be useful in theory anyways (my theory that is.. lol) is the fixing of the instance you get when you have your motors lag behind each other. Not taking sideways vibration into account, the only way you can move with square wheels is 4 times or 4 bump movements. I think if it is regulated enough with traction, that you can move forward equally between the motors in reverse directions on the sides of the bot.
Obviously, taking sideways vibration into account, the motion won't be absolutely straight, so maybe this post is just a useless one, but think about it at least.
Unread 07-01-2006, 19:01
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Square Wheels?
Square wheels seem like a good idea at first, but with this years game, you'll probably need the camera, and if there is any sort of movement like that at all, the camera is going to have some serious problems tracking the goal, not to mention shooting.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 08-01-2006, 17:34
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Square Wheels?
why in the world would you want to do that?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Getting A Bot To Turn Andrew Blair Technical Discussion 20 16-10-2005 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
