Go to Post Sometimes it is more appropriate for an individual to listen than it is for him to speak. - JVN [more]
Unread 07-01-2006, 20:42
r_towle r_towle is offline
FRC #1277
r_towle is an unknown quantity at this point
Drive System Dissapointment
This is our third year.
The first year we had to use the Bosch motors during our rookie year...all our failures were due to those lousy transmissions...
We had problems almost every heat that year...
So last year was such a relief that a decent tranny was included, simple and unbreakable...
So why was the second CIM motor replaced?
From what I can see, the original transmission design from 2005 will no longer work.
Rich
Unread 07-01-2006, 20:52
mobob17 mobob17 is offline
FRC #0011
mobob17 is an unknown quantity at this point
Exclamation Re: Drive System Dissapointment
I know after examining the new kit gearbox, that you are correct. you cannot use the same drive train from last year, but has anyone seen the build instructions for the 06' kit gearbox? Ive been looking for it for a few hours and the link in the FIRST page in section 5 is NO GOOD!
Anyone have any suggestions? were trying to just get one side running to test but i don't want to "If ALL else fails, READ the directions" method.
Tink
Unread 07-01-2006, 20:55
FRC #1277
Originally Posted by mobob17
[font=Tahoma] I know after examining the new kit gearbox, that you are correct. you cannot use the same drive train from last year, but has anyone seen the build instructions for the 06' kit gearbox? Ive been looking for it for a few hours and the link in the FIRST page in section 5 is NO GOOD!
Tink
out
well, it says to refer to the 2005 manual...
We watched the video again and it is the old manual for using two identical CIM motors...
Unread 07-01-2006, 20:59
FRC #0011
umm... that doesnt make any sense. why would FIRST supply us with a useless drivetrain kit /?? im sure theres something were missing here.
Unread 07-01-2006, 21:06
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Rich
You can run the gearbox with 1 of the old CIM motors.
Or, per rule R43, you can purchase 2 more of the small CIMs from last year and use 4 of them this year.
Unread 07-01-2006, 21:10
FRC #1277
This is great. So you can build one of your transmissions and test it..then order two more motors for the other one...
Alternately while you wait, you can run each tranny with one motor.
I guess I should read the manual.
Rich
Unread 07-01-2006, 23:11
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Good advice... ...closing the thread.
Joe J.
Team #88, TJ2
What teams have desgined a 6 wheel drive system? Alex Cormier Technical Discussion 41 24-11-2004 12:26
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
