Go to Post -dave "The Circular Saw of FIRST" lavery - dlavery [more]
Unread 07-01-2006, 22:52
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Measuring projectile poof balls
I have to say that's the best title i've ever used! According to the rules the balls can have a max speed of 28mph or 12 m/s. Obviously this is a important rule since it insures safety. It occured to me however, how do we measure the velocity of the balls?
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 07-01-2006, 23:03
Re: Measuring projectile poof balls
If you are using a pitching machine type device, you can use rotational motion principles.
V = r ω
V - Linear Velocity
r - Radius
ω - Angular Velocity
So, find the RPM of the output wheel, convert to Rotations per Second, then convert to radians per second. ω is a unit of radians per second.
That should give you a basic outline of how fast it will travel assuming a 100% efficient transmission of power between both items.
Unread 07-01-2006, 23:28
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Bushnell Velocity Radar Gun
"Baseball Accuracy: +/- 1 mph
Softball/Tennis: 6-110 mph/16 - 176 kph (100-ft away)
Auto Racing: 6-200 mph/16-320 kph (1300+ feet away)"
http://www.dickssportinggoods.com/pr...ductId=1845491 I've seen it at RadioShack as well, eBay has them for ~$80
SPEED WATCH
"Radar gun when this easy to use alternative calculates the speed of any object with an instantaneous conversion of time & distance to a MPH reading at a fraction of the cost."
http://www.opentip.com/product_info....ducts_id=38647 $28.54
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 07-01-2006, 23:44
Thanks both. That's one concern out of the way. Now number 204....
Umm Errr...
well there are a few ways. If you can shoot your launcher straight and measure the height it reached then use the formula v=sqrt(2gh)
it was derived from conservation of energy
kinetic energy = (mv^2)/2
potential energy =
mgh=(mv^2)/2
2mgh=mv^2
2gh=v^2
v=sqrt(2gh)
If you can't launch straight up but can launch straight ahead and measure the distance it fires from a known height then:
v=d/(.45sqrt(h))
where h is the height between the launch point and the floor. d is the distance traveled before hitting the floor. Everything must be in SI units.
1139 Alumni
Unread 07-01-2006, 23:47
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him.
I'm so glad the fields are indoor, having to deal with wind would be a nightmare...
Oh, maybe I shouldn't have pushed that...
Unread 07-01-2006, 23:52
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
We might just try this:
<S02> Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph).
As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30º from
horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be
considered unsafe per
<S01>.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 08-01-2006, 00:01
<S01>.
Which brings up concern 204! We talked about putting a spin on the balls but were not sure if it would do more to hurt then help.
Unread 08-01-2006, 00:40
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Heheh this year the matches are going to be NUTS! Volunteers will be running all around the sides of the field throwing balls that bounce out back into the field. Balls will be flying everywhere. None of the balls wil be allowed to go that fast, but 12 mph is still fast enough to take out a few unattentive judges
Let the chaos begin!
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 08-01-2006, 00:43
Billfred's Avatar
Billfred Billfred is offline
Careful on the units--that's twelve meters per second.
Unread 08-01-2006, 21:18
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
you could always use the beam sensor (parts KR61 and KR62). set the beam across the ball path, and have it measure the time during which the beam is broken. Combined with the ball diameter (7") you can figure out the velocity
Unread 08-01-2006, 21:36
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
I think that the proper spin would help more than hurt. If you launch with no spin (which is possible), I think that there would be a "knuckleball" effect, where the ball would basically dance and repeatability would be low. However, if you put the right spin, the ball travels further and in a more predictable trajectory.
The best way to find out? Prototypes!
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Good strategy? tkwetzel Rules/Strategy 45 17-02-2004 21:18
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
